Does anyone know what size bolt this is?
sup you guys, i have two bolts missing, the same bolt in two places. It is one of the 4 bolts that holds the seats in the integra, specifically the rear inside bolts (ones on rear, on inside near center console) these bolts are different sizes than the rest of the bolts holding the seat in, i'm missing both, doesn't anyone know what size this is? i don't have a bucket of bolts where i am right now to try different sizes..
take the bolts out of the other side behind the seats and take it to the hardware store and match up a nut that will fit the bolt correctly and then take the size of the nut and find the bolt that matches the same size for the nut and then buy the the bolt the same size and length?.....thats what i do
http://www.acuraautomotiveparts.org/...s=&view=normal
I believe u r looking for #9 : 90135-SK7-A01 BOLT-WASHER (10X27)
yea there is no bolt to remove and match up, as mentioned about, both are "missing". the rear of the seat is held down by 2 bolts, both are differently sized.. the smaller has a 12mm head, i'm thinking the larger will be a 14mm, but i have other 14mm head bolts that will not thread up, about the same diameter, just different thread pitch
