autopower roll cage ok to used on SP
Old May 9, 2009 | 01:25 PM
promotor's Avatar
Default autopower roll cage ok to used on SP
anybody knows if its ok to use the autopower roll cage RACE version or cusco roll cage bolt on SP?Street Power class...thanks
Old May 9, 2009 | 03:45 PM
boosted91crx's Avatar
Default Re: autopower roll cage ok to used on SP
cusco im pretty sure cant be used in any IHRA or NHRA due to its the wrong size tubing and all bolt in, the autopower can be converted to be used if you weld up the slip joints and also alter the mounting points to meet the rules.
Old May 9, 2009 | 11:18 PM
Boosted_B_Series's Avatar
I'd like to do a weld in cage, were can I get info on what will need to be modified to pass tech at the track?
MANOS K20EG
Feb 20, 2009 02:45 AM
TeamSTEALTH GSR
May 21, 2003 08:05 PM
275Performance
May 1, 2003 02:43 PM
