Sarter ?
Old May 9, 2009 | 01:03 PM
spens 91 Ef's Avatar
Default Sarter ?
is the starter grounded when it sits on the tranny and is that what makes a circuit and then makes it spin
Old May 9, 2009 | 01:31 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Sarter ?
Yes, starter gets ground from being bolted to the tranny.
The lug/bolt connection is your battery +.
And the spade connector is the low amperage connection to the ignition switch.
If you are bench testing it, you put a jumper cable '-' clipped to the case of the starter, the '+' to the lug and something like a 14 gauge to the battery '+' that you can intermittantly tap the spade connection with.
Old May 9, 2009 | 01:39 PM
its been tested and its fine i was trying to figure out how to make it spin all i could get it to do is pop straight out, bolting it up right now
Old May 9, 2009 | 02:05 PM
4drEF's Avatar
Keyboard Humorist
If you got it to pop out then it should spin.
Sounds like you have a bad starter.
Old May 9, 2009 | 02:19 PM
its been tested and fine, im getting a humming from my main relay and i replaced it now its still humming
D7KWagon
Aug 8, 2014 02:57 AM
3Rd_gEn_LuDE
Jun 5, 2011 07:33 PM
Nisif
Nov 3, 2005 08:34 PM
Superhatch
Dec 14, 2002 02:58 PM
