Suspension & Brakes Theory, alignment, spring rates....
Can tire size affect shock travel ?
Old May 9, 2009 | 12:52 PM
EFOSV.'s Avatar
Default Can tire size affect shock travel ?
I have this doubt , the car is a 95 toyota corolla station wagon , stock height its my moms car . shocks are pretty much new about 1 month and a half of use , sometimes the front bottoms out over bumps or little holes when riding with a passenger . its supposed to use 165/65/14 tires from factory but my dad installed 165/70/14 . anyone has an idea on this ?
thanks
Old May 10, 2009 | 07:35 PM
starion88esir's Avatar
Default Re: Can tire size affect shock travel ?
No. The tires will not cause that problem. In fact the car now has a slightly (5% of 165mm) larger sidewall which, so long as not overinflated, will actually provide more flex in the tires and less on the shocks. But being such a small amount, it is not enought to make any concernable difference.
Old May 12, 2009 | 10:57 AM
meljobin's Avatar
have you checked ride hight springs to wear out and if they have gotten weak you are going to have very low spring rates. seing as how it is the springs that hold up the car and not the shocks I would take a look there because they do wear out.
djtsmith007
Jul 30, 2009 11:00 AM
NosShootinHonda
Mar 27, 2009 12:04 PM
JDMhatchback20
Suspension & Brakes
13
Oct 20, 2007 08:05 AM
SoyMilk
Suspension & Brakes
18
Apr 2, 2007 12:09 PM
ezekel
Suspension & Brakes
Sep 21, 2006 10:47 AM
