need help!!!
Old May 9, 2009 | 10:34 AM
pimpchickpcfl's Avatar
Icon6 need help!!!
ok so i went to auto zone to have some codes pulled due to my 99 si coupe lagging under 3 rpm!! well only 2 codes came up being P1508 and P0420
ive already replaced the ignition coil, spark plugs, fuel filter, fuel injector, fuel pump, distributer cap and wires, and intake air temp
what else could it be can anyone help me
Old May 9, 2009 | 11:13 AM
Former User's Avatar
Default Re: need help!!!
Code P0420 suggests that you should check whether the cat is clogged. This could contribute to a lag or low power problem.
P1508 suggests that you may be having an idle problem. The problem could be the wires, the ECU, or the IACV itself.
Old May 9, 2009 | 11:16 AM
thanks a bunch! ill get the boyfriend to take a look at it
Old May 9, 2009 | 11:17 AM
forcefedferio's Avatar
yep, p0420 is for catalyst efficiency below threshold, replace the cat and go from there.
Old May 9, 2009 | 11:20 AM
but would that also cause it to hesitate and jump alot??
Old May 9, 2009 | 11:23 AM
When driving or idling?
Have you inspected or replaced the rotor in the distributor? Have you checked the ignition timing with a timing gun?
Old May 9, 2009 | 11:32 AM
i feel so used! j/k haha
The cat will cause the hesitation and lack of power, sounds like the IACV is causing your idle surge, try cleaning the IACV with carb and choke cleaner before spending money to replace it, but with it setting a code, it more than likely will need to be replaced.
Old May 9, 2009 | 11:44 AM
lol don't feel used but thank you so much i really wanted to get this car fixed cause my truck is doing it too lol.. but my truck is totally different if anyone has anymore ideas send them this way!! thanks
Old May 9, 2009 | 11:53 AM
while driving it jumps a little when idling at a stop light but not much its worse when the AC is on
Old May 9, 2009 | 12:52 PM
Fix the IACV and your idle problems will likely disappear.
Regarding the problems while driving, inspect or replace the rotor in the distributor and check the ignition timing with a timing gun.
Old May 10, 2009 | 10:52 AM
would the oxgyen sensor throw the p0420?
Old May 10, 2009 | 11:00 AM
If you don't have an O2 sensor code, then P0420 indicates a bad cat or an exhaust leak.
pimpchickpcfl
Mar 3, 2009 01:15 PM
iamlinu
Mar 29, 2007 03:32 PM
logikalfury
May 6, 2006 08:38 AM
Chaze*R
Aug 30, 2005 01:40 PM
civicferio8381
Apr 6, 2005 06:20 AM
