Antiefreeze leak from hell
Old May 9, 2009 | 09:07 AM
coryfenton's Avatar
Default Antiefreeze leak from hell
Hey, so im just about to finish up the swap on my civic last night...
So i start puttin in the anti freeze and it starts leakin from the Fu**ing head, so pulled the head again and everything looks good. My question is: If I have ls head bolts would it cause it to leak really bad??
I bought the car with the lsvtec before, and dont know if they put in ls bolts or b16. I measured them and they are longer than they should be... j
just wondering guys.. thanks
Old May 9, 2009 | 09:09 AM
memorybox's Avatar
Default Re: Antiefreeze leak from hell
Can you move the head when you torque it down? If the water is coming from where the head surface meets the block then yes you need to change head bolts.
Old May 9, 2009 | 09:19 AM
XKINGX's Avatar
lsv use gsr head bolts or head studs would be better.
Old May 9, 2009 | 09:47 AM
coryfenton's Avatar
Yeah I never checked too see if it moved but what else could it be??
I honestly forgot to check.. But it probably did, I just was thnkin ya know that's the only possibiilty to me
Old May 9, 2009 | 02:24 PM
coryfenton's Avatar
anyone?? i really need help....
Old May 9, 2009 | 04:09 PM
Dangousity's Avatar
sounds like the bolts bottomed out and your torquing them into the thread bottom.
Old May 9, 2009 | 05:17 PM
coryfenton's Avatar
so getting b16 bolts should fix yeah??
Old May 9, 2009 | 05:58 PM
Dead CIVIC's Avatar
Veteran: Army
Arp!
Old May 9, 2009 | 06:01 PM
steveo135's Avatar
Originally Posted by coryfenton
so getting arp studs should fix yeah??
fixed
was a new head gasket used in the building of this ls-v?
Old May 9, 2009 | 11:10 PM
coryfenton's Avatar
It is no longer an ls-v.
Its just a stock b16a2, new oem headgasket from honda yes, and i got some golden eagle ones for a steal, are thay any good??
wantboost
Apr 30, 2011 05:28 PM
JdM_RACeR07
Oct 19, 2006 12:43 PM
riceball777
Oct 25, 2003 01:56 PM
fukaintmuven
Mar 7, 2003 10:57 PM
logistixz
Oct 8, 2002 06:20 PM
