How to take out TB spring?
How do you take out the "spring & plate" on the throttle body?
So far I took off the 11mm nut & "un-hooked" the spring from both ends.
What is next?
TIA
Figured it out
1) 11mm nut with lock washer
2) loosed the 7mm nut, while keeping it still on the bolt, use small allen key to loosen the "thread contac" from plate.
3) un-clip both hook-ends of the spring
4) use flat-head to slightly pry it off, it will come off after maybe 2-3 taps. ... and don't worry the spring won't shoooot out or anything... lol
exgr
18
Oct 29, 2010 02:14 PM
Understeer
71
Dec 19, 2007 08:57 AM
seeeya04
Suspension & Brakes
10
Jan 16, 2005 06:24 PM
