Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
k24 swap!! ...help!!
Old May 9, 2009 | 06:54 AM
lsalbarran's Avatar
New User
Default k24 swap!! ...help!!
I'm planning on building a k24! Buy I'm NLT site exactly witch block to use! I have a block from an 08 cr-v and a block from an accord!! I have an Si head that I'm gonna use! I'm planning on rebuilding the block and I know I'm gonna have to do some mods to it! For example like the oil filter cooler!! Has anyone done this! Or know where I could find some useful information???
Old May 9, 2009 | 06:57 AM
lsalbarran's Avatar
New User
Default Re: k24 swap!! ...help!!
^^^ I'm not sure what block to use^^^^ sorry typo since I was doing really fast on my iPhone!
Old May 9, 2009 | 07:41 AM
ekb16's Avatar
u can use wutever block u want..its really up to u..if u cant bigger displacement n some tq go wit the k24..if u wanna rev alittle higher go with k20 block..
yes the oil cooler conversion has been one
k20a.org is ur new friend..lots of helpful information
Old May 9, 2009 | 07:46 AM
i-VTEC_DOHC's Avatar
get a tsx block.
Old May 9, 2009 | 07:59 AM
lsalbarran's Avatar
New User
Thanks...machine shop is gonna prob have to do thAt oil cooler right since the block is gonna have to be drilled
Old May 9, 2009 | 08:09 AM
ekb16's Avatar
well if u go on k20a.org and search one of the stickys i believe it will show u how u can do it urself..yes it does require u to drill into the block
lsalbarran's Avatar
New User
On the cr-v the oil filter is located at the bottom of the block by the oil pan! N the acoord is behind where the k20 is but no oil cooler...
Old May 9, 2009 | 08:36 AM
ekb16's Avatar
if u plan on running a OEM style oil cooler i would run the accord block that has the oil filter that sits on its side...there isnt any real diff. between the k24 blocks besides the k24a2 block which has oil squirters..i noe on the new k24 the bottom half of the block has the oil filter on it but i havent seen anybody yet run those block
Old May 9, 2009 | 08:39 AM
^ thats why i said k24a2 a.k.a tsx
Old May 9, 2009 | 08:48 AM
ekb16's Avatar
read thru the thread it will help u out
http://www.k20a.org/forum/showthread.php?t=34850
HseriesWeaksauce
May 23, 2009 01:29 PM
K_KrazyAzn
Dec 15, 2005 11:37 PM
mo0cow
Oct 26, 2005 04:36 AM
shingles
Oct 22, 2002 08:25 PM
highbrid
Oct 14, 2002 08:33 AM
