running rich why???
Old May 8, 2009 | 09:54 PM
mikester1222's Avatar
Default running rich why???
my crx with b16 swap in it is running really rich i cant figure out why. its not throwing any cel codes can anyone shine a light on the possiblities?
thanks
Old May 8, 2009 | 10:05 PM
88_acED6's Avatar
Default Re: running rich why???
ecu?
timing right?
Old May 8, 2009 | 10:12 PM
what exactly such as map sensor o2 sensor exc. would be cousing it to run so rich it runs choppy untill you get to high rpms then its fine.
Old May 8, 2009 | 10:15 PM
88_acED6's Avatar
is it throughing any codes?
if not check your dizzy timing mine was doing this
Old May 8, 2009 | 10:34 PM
its not throwing any codes whats the dizzy timing?
Old May 8, 2009 | 10:51 PM
ok i figured out what the dizzy timing is could it be a vacuum line problem though?
Old May 8, 2009 | 11:45 PM
88_acED6's Avatar
don't think a vaccum leak would do this at all....
Old May 9, 2009 | 02:54 AM
4DRmafia's Avatar
Just curious and also I don't mean to thread jack but how can I know if my car is running rich? Will it have the gas smell smoke coming from the tailpipe?
Old May 9, 2009 | 08:33 AM
yeah thats what mine is doing and its running crappy at low rpms but once you get near 5 it runs good
Old May 9, 2009 | 09:15 AM
my spark plugs are all black as well is it possible i have it is a dx and i had to wire in the injectors and everything is it possible i have wires criss crossed somewhere? if so what ones would do it?
Old May 9, 2009 | 09:34 AM
4DRmafia's Avatar
I haven't driven mines much after the new piston rings install. Only have 40 miles on and it been sitting for 2 weeks. I need to drive it more to see. I think timing would cause that or a bad fpr?
Old May 9, 2009 | 10:25 AM
88_acED6's Avatar
check your timing!!!!!!!!!!!!!!!
Old May 9, 2009 | 12:09 PM
autowrench07's Avatar
Is your fuel pressure regulator vacuum line hooked up to the corect port on your intake mani? If u dnt have that hooked up right it would dump a lot of fuel and since its running the same percentage through all rpms it could be something with our computer. If its reading a wrong rpm it will run as if its reved out
Ef4doorwagon
Jul 11, 2015 11:08 AM
Jet Black
Nov 25, 2006 06:49 PM
herde1724
May 15, 2004 02:11 PM
