New - Hondata FlashPRO
Just figured I would let you guys know that Hondata has introduced a new solution to tuning for 06 and up civics.
Hondata FlashPro
The FlashPro allows full user tuning and datalogging of late model performance Civics. It includes Windows based software called FlashProManager.
The FlashPro connects from your laptop's USB port to your vehicles diagnostic port to provide 90 second programming with a variety of calibrations with extensive real time and stored datalogging capabilities.
Supported vehicles
* 2006 + US Civic Si (RRB-A01 through RRB-A14)
* 2007 + European Civic Type R (RSP-E01 through RSP-E03)
* 2007 + Japanese Civic Type R (RRC-J01 through RRC-J04)
Price and availability
$795 in June 2009
Features
FlashPro features
* Programmable ECU interface.
* Connects via OBDII diagnostic port.
* USB 2.0 connection
* Works with Laptop or Desktop
* No ECU modification necessary.
* 90 second ECU programming time.
* 20 hours on board datalogging memory.
* FlashProManager Windows software.
* Check and clear diagnostic codes.
* Custom laptop gauges.
* Theft mitigation
2006+ Civic Si / Civic Type R tuning features
* Choice of AFM or MAP based tuning.
* Support for MAP based forced induction.
* Support for larger injectors.
* Ignition, fuel, cam angle table editing.
* VTEC window.
* Rev, launch and speed limiters.
* Race vehicle sensor disabling.
* Plus other compensation and trim tables.
* Map tracing
What do I need to run the software?
* Windows laptop or desktop
* Windows XP, Vista or 7
* USB 2.0 port
* CDROM Drive
Training videos
We're putting together a series of training videos to describe the function and use of the FlashPro. Check back in a week's time for several extensive training videos.
Will the FlashPro be available for other Hondas and Acuras?
The FlashPro has the potential to work with most new model Hondas and Acuras made since 2007. Our focus for the moment is for the Civic and will evaluate other models as time permits.
I already have a reflash. Is there a discount?
Yes, for 3 months from the date of release a discount is offered to existing Civic Si reflash owners. In order to qualify for the discount, the ECU will need to be sent to Hondata where the the FlashPro is locked to your ECU.
The discount is $150 for existing Civic Si reflash owners which includes free overnight return shipping. (additional $50 value)
If you choose not to send in your ECU for a discount the FlashPro will still work perfectly for your car.
How does it compare to KPro?
KPro is a completely different product. It was created for the 02-04 RSX style ECU. It will only work on that type of ECU with the exact same Oki processor. Honda has changed the architecture of the ECU, including ECU architecture, processor and encapsulation, so that there is no way the KPro can be made to work on any other ECU.
K-Pro requires the ECU be sent to a Hondata for the installation of the K-Pro daughterboard. By comparison, new FlashPro owners need never remove the ECU from their car.
Because FlashPro is a different product from KPro, it has different features. Not all features implemented in KPro are possible with FlashPro.
Hondata FlashPro
Supported vehicles
$795 in June 2009
Features
FlashPro features
* Theft mitigation
* VTEC window.
* Map tracing
* USB 2.0 port
* CDROM Drive
Training videos
This is even better for the ones that were saving up to run the pibbyback ecu to run k-pro.
I have a few ? I'm wondering if its possible to swap the dbw to cable and would it work .This would be great news if its posibble since i cant stand the dbw.
http://www.toda-racing.co.jp/en/prod...on/k20a-5.html.
imma have to do more research
! nothing like a competitor putting a little pressure on hondata to speed things up
