engine swap
Old May 8, 2009 | 04:50 PM
prelude_problems's Avatar
Default engine swap
i gotta 2001 sh with a bad h22 v techs gone barely anypower. what would be the ebst engine tot rhow in there thats good to turbo?
Old May 8, 2009 | 05:04 PM
iwanttokillgod's Avatar
Default Re: engine swap
what the hell is a bad h22 v techs also (ebst engine tot rhow) not to be mean but r u dyslexic
Old May 8, 2009 | 05:25 PM
Hawkze_2.3's Avatar
Please read the FAQs....if you can.
Old May 8, 2009 | 05:52 PM
ajason24's Avatar
learn how to type before you start workin on a car
Old May 9, 2009 | 06:19 AM
wow whata bunch of ******** sorry i mispelt some thing i was tired and wanted to post this real quick. my question is what is the best engine to throw in my 2001 sh because my h22 is weak. its been beat on for 80000 miles the vtecs gone it bogs out and doesnt boost and im not paying 375 to replace it and it has the atts system which isnt good for boost so if ne 1 can help me let me no otherwise if your guna be a dick dont bother
Old May 9, 2009 | 06:55 AM
jnv255's Avatar
Explain what ur car is doing.. No need to replace if u can rebuild.. A loss in power while in vtak could just be something small.
Old May 9, 2009 | 07:11 AM
Honda Sport's Avatar
low oil pressure, low oil, clogged VTEC solenoid, inop VSS, etc. could all cause VTEC not to engage.
any h22a longblock will fit but since you're going to boost(or already boosted) you might as well build your old motor.
Old May 9, 2009 | 08:05 AM
375 is cheap to replace a h22 sh motor
Old May 9, 2009 | 08:34 AM
lrayford's Avatar
yeah id just fix you motor with 80k on it and roll that that.
who puts a motor in when a bad switch at worst is the the problem?
but if you wanna know the answers.
another h22 is the way to go. but why
Old May 9, 2009 | 10:59 AM
yea ur right i had low oil pressure and oil and the switch was bad and filter was clogged or sumtin but i fixed it and boostin again but another question would it be safe to put a turbo on with this many miles? also if i get sumthing like the hondata can that be tuned on a dyno?
Old May 11, 2009 | 06:40 PM
hheard15's Avatar
there is no other motor besides the H22 that you could put in there. you would be wasting your time to try and put a different H22 in there because that model is all wired up for that stupid ATTS **** and you would have to get all that unwired which would be a pain in the ***.....375 is the cheapest you could possibly go...you might wanna read up on H22s and see for yourself how much they run for especially the H22A4 (ATTS) version...
Old May 11, 2009 | 07:01 PM
MikeLuder's Avatar
not tryin to dog you bro but why you spellin it 'V-Tech' when it says VTEC on your valve cover?
Check your oil pressure, have a massive tune-up done, Everything, NGK plugs, Wires, Quality distributor cap & rotor, new fuel filter, Valve Lash Adjustment, EGR cleaning with seafoam, new air filter, replace o2 sensors with Denso, replace catalytic converter.
thats gonna run you a couple hundred bucks, but it'll definitely run more prime.
Once you do all that, go get yourself a quality header like the new Tri-Y or Vibrant, ect.
get a quality tuning devise like a VAFC Neo or Greddy Emanage since you got the Atts
Old May 12, 2009 | 03:52 PM
jerrym88's Avatar
yeah i would have to go with luder on this one. it will be well worth it. i have a a 91 honda accord lx and i going to swap the f22a with the h22a, i was wondering is there any problems i should be worried about? i heard its a str8t drop in, any advice anyone?
92accordundrconst
Apr 3, 2006 11:54 PM
HondaVTEC1993
Dec 16, 2005 06:40 PM
neronian
Mar 29, 2004 07:16 PM
neronian
Mar 28, 2004 12:21 PM
neronian
Mar 26, 2004 10:56 AM
