99-00 Headlights Problem, Please Help
I ran into some problems with my new High/Low HID last night.
I have my HID installed 4 years ago, and the seller installed the HID. The seller now IS disappeared, therefore, I have no way to get solution from him.
The old HID kit is made by mccullough hid with low beam only "no extra bulbs non HID high beam", so whenever I turn on high beam, the HID will shut and keep in mind. The blue light in the cluster does not indicates rather the highbeam is on or off.
Finally the day has come and I have to change to another set HID kit,
since the old one is not running probably. I decided to install the High/Low beam HID, but after I installed it, I realized the car allows low beam only and no High beam. Then I tired a normal H4 bulb, unfortunalty, yes DRL and low beam but no luck with high beam.
Weird thing is, I tested with the new HID kit, when i turn on with low Beam. The HID bulb itself flicks between Low and high beam constantly.
My question is, does anyone have any experience with mccullough HID. Since its an old HID kit, does it required to disable highbeam in order to make it work? does it have anything related to wiring?
I would like to get a diagram to show the 99-00 headlights wiring diagram.
Weird thing is even with a normal H4 bulb, it has no highbeam, just DRL and low beam only.. another weird thing is whenever i turn on the highbeam, the indicator in the cluster doesn't light up.
Thank You
Thank You
Toxin715
Dec 29, 2016 04:55 AM
