Vtec Head Plug Question
Old May 8, 2009 | 12:07 PM
Cruzan77's Avatar
Default Vtec Head Plug Question
Is an 1/4 NPT plulg to big to plug the head? I believe that the current plug went in cross and is leaking oil bad.
Thanks?
Old May 8, 2009 | 03:26 PM
onepoint6i's Avatar
Default Re: Vtec Head Plug Question
Thanks?
yes 1/4 is too big, did you apply teflon or hondabond to the plug before putting it in to the head?
Old May 8, 2009 | 09:11 PM
Cruzan77's Avatar
We put Honda Bond on the plug but no teflon. Any suggestions on stopping oil leak? The car is loosing about a quart of oil a day. Think we will pull his head and apply teflon and hondabond to the pulg this weekend.
Old May 9, 2009 | 07:34 AM
Str8EJ's Avatar
I'm fairly certain you're supposed to use a 1/8-27 npt plug at the head. 1/4 sounds much too big.
Old May 9, 2009 | 01:55 PM
onepoint6i's Avatar
Hondabond should be sufficient, mine was leaking when i first installed it too, i pretty much pulled off the plug, clean it up real good inserted the plug with plenty of hondabond and tightened it into the head as far in as it goes..I have no leaks whatsoever..avoid the teflon imo..hondabond is the best.
Old May 9, 2009 | 05:59 PM
Farmer89511's Avatar
yeah i just used teflon tape and never had a problem so far...lol
Old May 10, 2009 | 08:06 PM
Cruzan77's Avatar
Thank You. Will try again tomorrow with more Honda Bond.
big June
Jun 7, 2013 01:37 PM
Teamdiesel
Mar 7, 2010 05:47 PM
gutted-dx
Nov 8, 2009 08:31 AM
2redstars
Nov 1, 2006 04:30 PM
