EF b16 obd-0
I'm having issue with the motor not turning over. So basically I took the car in for a smog check and the machine could not get a reading for rpm. They tried different moving around to different parts of the wire and still no reading. So we figure it might be the distributor. I bought a used distributor and then it just wouldn't turn over. The buyer says the distributor was good when it was pulled off the motor. I noticed two wires loose from the larger harness plug on the distributor. Either they were loose before or had broken off when I had changed distributors. I fixed the wires and now All I hear is the starter when I try to start it up. The engine does not turn at all. Any ideas on what it could be?
I changed the starter and I get the same problem so I guess it wasn't the starter. My friend suggested that I try to manually crank the engine to see if it had seized.
any other ideas?
any other ideas?
javiergt02
15
Aug 21, 2006 07:37 PM
chirp2hrd
Jun 3, 2003 02:19 PM
Dank26
Nov 13, 2001 07:20 AM
