D16Z6 swap in my EF What should I know?
Old May 8, 2009 | 09:29 AM
esurds's Avatar
Icon2 D16Z6 swap in my EF What should I know?
Hey I'm going to be doing a D16Z6 swap out of a 1994 honda civic Ex. What do I need to know to get it to work? Should I use a p28 with jumper wire? Will it bolt right up? Just let me know what you know about these swaps. Thanks Eric
Old May 8, 2009 | 12:43 PM
dephtone's Avatar
Default Re: D16Z6 swap in my EF What should I know?
Direct bolt in, buy a conversion harness from obd0 - obd1. If you buy a conversion harness this will have the wire for vtec and the pressure switch.
Old May 8, 2009 | 01:21 PM
clovis88crx's Avatar
also need a cable to hydro clutch kit
Old May 8, 2009 | 03:23 PM
jo7man4's Avatar
you dont need the cable to hydro clutch kit if he is gonna stick with the ef transmission just as long its not a 4 speed
Old May 8, 2009 | 03:31 PM
crxblues's Avatar
if ur car isnt a si than ur gonna need and si throttle cable
Old May 8, 2009 | 04:14 PM
91ed6dx's Avatar
i got a d15b2 block with d16z6 head and the wiring was a bitch
Old May 8, 2009 | 04:25 PM
slmd2ndgen's Avatar
any luck yet?
Old May 8, 2009 | 05:11 PM
nfereorhatch's Avatar
Its not a "direct bolt in", you need to swap the stock driver side mount onto the z6 for it to line up correctly. Also i found that the throttle cable from the 94 chasis worked very well and looked "neater" than the stock one since its shorter. Other than that buy yourself a good conversion harness wire it up and enjoy.
Old Oct 24, 2009 | 07:33 AM
lovemyef's Avatar
u can also take the motor mount bracket off with 2 bolts and bolt on the one off of ur current motor i did it works great and dont have to buy new motor mounts if u r trying to save money
tyked15
21
Nov 8, 2010 05:36 PM
adobo310
Mar 9, 2010 08:14 AM
bumm03
Feb 28, 2010 08:24 AM
crxtra
16
Jun 29, 2006 09:46 AM
D3U1LT
Sep 20, 2004 05:52 PM
