gsr 1' brake setup on a crx
Old May 8, 2009 | 08:07 AM
kojack_0's Avatar
Default gsr 1' brake setup on a crx
ok, i have searched and search, both on honda-tech, other forums, and google for the answer i need. and nothing.
im trying to figure out if a gsr brake booster and master cylinder will fit in a 89 crx si and how well does it work?
when i compared them the hard lines for the gsr setup are obviously bigger and i have to bend lines.
people have different asnwers and doesnt really answer the question. people say just get an RS setup, or an Accord setup, or a 90-91 Civic EX setup. thats not what i really wanna do, because a gsr setup is staring me in the face.
i have:
gsr rear disks conversion w/ e-brake cables.
gsr master cylinder.
gsr brake booster.
gsr brake fluid solenoid/reservoir.
gsr '40/40' proportioning valve.
these are all going an 89 crx si.
anyone got experience with this?
Old May 9, 2009 | 02:48 AM
kojack_0's Avatar
Default Re: gsr 1' brake setup on a crx
29 views. cmon ht i know someones got experience.
Old May 9, 2009 | 05:35 AM
K2e2vin's Avatar
I'm using just a 1" ABS master cylinder/booster with 90-91 EX brakes. I actually plan to go bigger though. Only *issue* was the different size fitting; the Integra uses a 12mm tube nut and 10mm. I simply used a what seemed to be difficult-to-find adapter(I actually found it by accident).
Old May 9, 2009 | 11:36 PM
kojack_0's Avatar
goodness!! perfect!
you know what size the adaptor is?
from what size to what size?
did everything bolst up fine? people said it wouldnt work cause its abs, i dont understand that if abs has its own control unit why does the booster/master cylinder have anything to dowith abs.. please enlighten me with some info.
Old May 10, 2009 | 02:57 AM
K2e2vin's Avatar
10mm(f) to 12mm(m) inverted flare. The bag said simply "12mm adapter"
It works just fine. Difference between ABS is ABS cars have a ABS unit; that's also not part of the master cylinder. In other words; ABS has no effect on whether or not a master cylinder will or will not work.
Old Feb 26, 2010 | 12:05 PM
ef red devil's Avatar
PART number is (BLF-36c) sold at autozone. AGS/M12 - 1.0 bubble male to M10 - 1.0 inverted female port carded japanese brass brake adapter for 3/16 in. line http://www.autozone.com/autozone/cat...System+Adapter
Old Feb 26, 2010 | 12:09 PM
alscrx's Avatar
PM'd you!
Old Feb 26, 2010 | 10:16 PM
Clipsed's Avatar
Bump from the mu****in dead! lolz, but thanks, went and bought that today!
Old May 27, 2010 | 03:01 PM
xymantec's Avatar
Awesome thread, solved a potential headache.
Old May 27, 2010 | 04:00 PM
Red_ED8's Avatar
Originally Posted by kojack_0
i have:
gsr brake booster.
gsr '40/40' proportioning valvei.
Not trying to thread jack or talk down to you but just so you know all integra's except Type R's have the same calipers, m/c's and b/b's.
GSR m/c part #46100-ST7-L52
LS m/c part #46100-ST7-L52
Chack the links and see:http://www.hondapartsunlimited.com/i...99&version=3DR GS-R (LEATHER)&transmission=KA5MT&section=CHASSIS&compo nents=BRAKE MASTER CYLINDER&submit=submit
http://www.hondapartsunlimited.com/i...99&version=3DR LS&transmission=KA5MT&section=CHASSIS&components=B RAKE MASTER CYLINDER&submit=submit
Old May 27, 2010 | 04:06 PM
xymantec's Avatar
haha yeah right thread jacker
Old May 27, 2010 | 04:10 PM
Red_ED8's Avatar
lol I know, I know. I just see people make this mistake WAY to offen and some even end up paying more for those so called "GSR brakes".
Old Jan 25, 2011 | 01:22 PM
theft24's Avatar
thats not the the right fitting, the bubble one will not work unless you some how take the brass piece out of the mc
Old Jun 17, 2013 | 08:38 AM
erbavour's Avatar
Do you know for sure?
Old Jun 18, 2013 | 05:34 AM
erbavour's Avatar
Yea homie above me is right on the money. The bubble wont mate good with MC fitting inside. Needs a inverted flare to do so. Went to "u-pull" yesterday and got the correct fitting. Any 94-97 integra mc return line fitting (looking at it str8 up left side one) will do.
little2fast4u
13
May 10, 2010 12:31 PM
kojack_0
May 7, 2009 04:34 PM
ventturei27
Nov 22, 2006 07:58 PM
Leb_CRX
Jan 31, 2005 08:40 PM
hybrid_eg
Mar 13, 2003 12:09 PM
