Suspension & Brakes Theory, alignment, spring rates....
best fixed height shock set up
Old May 8, 2009 | 01:35 AM
krazy one's Avatar
Default best fixed height shock set up
I am looking for some input on fixed height shock set ups that is dampening adjustable. It's for a daily driven EG, that is taken occasionally on autoX and mountain runs. some friends and shops have pointed me toward koni yellows with swift springs, while others recommended (if have the $) toward Mugen lowdowns. Up for some input everyone.
Old May 8, 2009 | 01:59 AM
92civiceg9gsr's Avatar
Default Re: best fixed height shock set up
You cant go wrong with konis. Any well known spring will work well, it kinda just depends on the drop you want. I like H&R.
Old May 8, 2009 | 09:34 AM
krazy one's Avatar
i want a drop similar to the mugen lowdowns or slightly a little lower, along with adjustable dampening that can handle autoX courses and winding roads. I have the TEIN SS w/o pillowballs on right now, so if i find a shock that has similar handling if not better, then that will be great. im done with a dumped ride height, i want a nice ride height that has good shock travel and not worry bout speed bumps too much, also not attract too much attention to the boys in blue and thieves..
Old May 8, 2009 | 11:25 PM
krazy one's Avatar
any input HT?
Old May 10, 2009 | 10:40 AM
krazy one's Avatar
bumpage
Old May 11, 2009 | 11:58 PM
krazy one's Avatar
ok so from searching i came across the TEIN NA/NR. any input on them? do they even exist anymore?
WhiteGSR95
Feb 14, 2011 11:03 PM
perpetualburn
72
May 9, 2007 05:09 PM
19codyscivic94
Dec 16, 2005 02:02 PM
ieatrice
Suspension & Brakes
10
Jan 31, 2005 12:30 PM
suprafly20
Jan 25, 2002 10:14 AM
