How tp Brake fluid bleeding with drums?
Old May 8, 2009 | 12:34 AM
hermtm2's Avatar
Default How tp Brake fluid bleeding with drums?
Hello.
I have bleeded all-four-disk brake system. However my 2000 EX has only front disk brakes and rear drums. How to bleed the fluid to rear drums? Are they the same as the front disk brake? I mean I used to begin from rear passenger side to end up the front driver side at all disk brake system. Honestly I haven't worked with the drum brake yet. How to deal with the disk + drum brake system?
Thanks.
Old May 8, 2009 | 01:44 AM
trustdestruction's Avatar
Default Re: How tp Brake fluid bleeding with drums?
I believe you do it with the same method, via a bleed bolt near where the brake line meets the back of the drum.
Old May 8, 2009 | 02:44 AM
MIsterE533's Avatar
Bleed drum brakes same as disc. Just make sure the drums are adjusted and you get 2-4 clicks out of the E-brake before you bleed. And for your own sake so you don't blow the wheel cylinders out, make sure the drums are on and over the brake shoes. And yes the bleeder screw is right above the brake line and its an 8mm head on the screw.
Old May 8, 2009 | 10:33 AM
hermtm2's Avatar
I will replace the front brake rotors and then flush old fluid out to the entire system.
Thanks.
Jaydeep
Jun 25, 2012 09:25 PM
dingobat
Suspension & Brakes
Mar 2, 2010 10:27 AM
tommyofyork
Apr 8, 2007 05:45 PM
LS_REX
Mar 4, 2004 06:15 PM
