CTR Pulley, Brake Lines, Camber Kit, DA parts...
Old May 7, 2009 | 06:30 PM
Colin's Avatar
Default CTR Pulley, Brake Lines, Camber Kit, DA parts...
Got some random stuff for sale. I'm VERY busy, so please don't waste my time. Prices are flexible to some extent, but I feel they are also fair. Prices do not include shipping or paypal fees.
Not really looking for trades since I have most of what I need to finish the first phase of my track car build - but feel free to ask. May consider Canon camera accessories for my 40D.
1) CTR N1 Racing Crank Pulley $65
- BRAND NEW - Took out of OE Honda packaging, mounted on engine (w/o bolt or key) then removed in favor of a custom piece
- InlineFour sells these for $100 and you can find them used for what I'm asking
2) EARL's Braided Stainless Steel Brake lines $40
- 90-93 Integra
- FRONT ONLY
- Brand new, bought them off a g2ic member as a set w/ the lines below, never installed, never used...
3) StopTech Braided Stainless Steel Brake Lines $40
- 94+ Integra
- REAR ONLY
- stainless w/ plastic sheath/coating
- Brand new. Bought these as a set w/ the above lines. I have DC trailing arms and the stainless lines I have already don't fit right so I bought these thinking they would work. But unfortunately it still doesn't match up how I want. I don't think there is a brake line on the market that mounts properly on a DA w/ DC TA's.
- These are high quality lines, they look to be better than Earls or Goodridge. If I was in the market for a new set of lines I'd get StopTechs
4) Anchor Bolt Type Camber Kit $40?
- No idea what brand (Duy, where you at?)
- Adjustable, two settings. I don't know what they are
- These were used in conjunction with Vision UCA's
5) OBD0 Injectors $10
- Approx 185k miles
- Working when pulled 6yrs ago
- As far as I can tell only one pintle cap is cracked
- Includes OBD0 injector clips
6) Driver Side Mirror $5
- Milano Red (faded and some normal freeway chipage)
- Worked fine when removed, all wiring included
7) Rear Floormats $10
- Good condition, not mint, but not abused
8) A/F Ratio meter $5
- progressively lit LED's
- instructions included
9) Underhood Fuse Box $5
- pretty sure this came out of my 91 GS
10) Skunk2 Adj. Cam Gears $40? SOLD
- Older version, probably around 5yrs old?
- I removed them from a set of CTR cams which were in a b17a. Engine ran fine for years, was dyno tuned... Didn't even know about the issue below until the gears were removed.
- On one of the gears there was some slop (you can see in the pic) between the cam, woodruff key, and gear . Cam survived, gear looks OK but a little scuffed inside, but the woodruff key is mangled.
- I suspect these would be 100% OK if you smooth the burrs on the one cam w/ some fine grain sand paper and use a new woodruff key - but I'm not making any promises. These are sold AS-IS.
One More And Another
Everything on this list, or in
/ photset (but NOT mentioned above) ONLY $1 (min $5 shipping charge unless picked up)
1) Oh-**** handles (may be a front and rear, they look a little different)
2) Shift ****
3) Hatch / Gas door release lever and cover
4) Map Lights
5) Hood Release Lever
6) Rear wiper motor
7) Rear wiper
8) Gas Cap
9) Misc covers
10) Taillight "vents"
11) Misc interior and gauge light bulbs
12) Steering Column cover (underside)
13) Misc USDM headlight bulbs and associated connectors/plugs
*** Local Pickup in Long Beach is preferred. I'm usually available weekday evenings.
*** Contact me with your zip code and I can get a shipping quote for you
*** Since I'm busy I can only ship ONE DAY A WEEK. Most likely Monday.
*** I ONLY accept PAYPAL or CASH. Don't like it? Then sign up for paypal!
*** I have plenty of good feedback here and on ebay
*** Reply here or Email: 1colin (at) gmail (dot) com
Old May 7, 2009 | 06:33 PM
Too_slow_eg's Avatar
Default Re: CTR Pulley, Brake Lines, Camber Kit, DA parts...
bump for a cool guy
Old May 7, 2009 | 11:09 PM
da9leo's Avatar
I <3 DA's
Old May 8, 2009 | 05:31 AM
Colin's Avatar
Thanks guys!
sl_e_pr
Jan 13, 2007 01:38 AM
LvN
19
Aug 24, 2006 02:39 PM
cxhb
Jun 22, 2006 09:08 PM
PsychoSiRex
Oct 14, 2002 11:25 PM
