Should the motor die when you unplug the iacv?
Old May 7, 2009 | 01:49 PM
absinthminded's Avatar
Default Should the motor die when you unplug the iacv?
Car was warmed up and i unplugged to see what would happen and it died immediatly, is that supposed to happen?
Old May 7, 2009 | 01:55 PM
crazyc@SRTmotorsports's Avatar
Default Re: Should the motor die when you unplug the iacv?
ONLY IF THE IDLES SET TOO LOW, NORMALLY IT'll just start fluctuating but not die
sorry for all caps ha
Old May 7, 2009 | 02:02 PM
Adankid's Avatar
quick noob question,,,,,,,,
what is this iacv everyone talks about?
idk what the abbreviation stands for.
Old May 7, 2009 | 02:12 PM
intake air control valve: it controls idle and cold start up, AC command, PS command, any rise in electrical load. helps engine run smoothly
Old May 7, 2009 | 02:22 PM
When i unplugged it the idle was around mid 700 to 800 rpm, is that the spec on a gsr?
Old May 7, 2009 | 06:14 PM
LOVEthatDC2's Avatar
x2
leftyfork
Oct 6, 2010 08:05 AM
95SiPrelude
Apr 2, 2009 05:31 PM
Bigmman
Sep 24, 2008 01:38 PM
BLANCOh22a4
Oct 22, 2007 10:03 AM
