Clutch Master Cylinder issues--
Old May 7, 2009 | 12:00 PM
Teggygrl08's Avatar
Default Clutch Master Cylinder issues--
vehicle: 2000 GSR
well.. not so great news. woke up this morning and notcied my clutch has no pressure, it doesnt stick to the floor but it definitely doesn't feel right- and engages down on the floor. checked behind the pedal and sure enough, a damn leak. i topped off the fluid and it feels almost normal, and im bleeding it tomorrow... but i guess i should still replace the cmc, otherwise it'll keep leaking. my mom wants me to sell my car, because i've had to do a ton of maintence since i've owned it
its $155.13 from my acura stealership.
has anyone had any luck with cmc's that arent OEM? like PBR or beck arnley? they're about 60-80 dollars which is a lot cheaper for me. I'm also looking at partouts around my area but im afraid if i use another high mileage one, it'll go out in a few thousand miles as well. but just in case, does anyone know if the engine matters? like can i use a cmc from a b18b or a type r? and does the year matter or can i use any 94-01?
thanks for the help :/
Old May 7, 2009 | 12:57 PM
Jspek_Inspired's Avatar
Default Re: Clutch Master Cylinder issues--
http://www.acuraautomotiveparts.org/...s=&view=normal
#6 & #8.
$50 dollars cheaper than your dealership.....
Old May 7, 2009 | 01:10 PM
jdm_bones's Avatar
Makes don't matter...Used ones are ok, go to your local junkyard...I am sure you'll pay like $40 for one...Have someone help you out when you bleed it, don't let the pedal sink all the way down to the floor, as that can damage it.
danteisme
Aug 28, 2007 05:34 PM
RaceMyGhost
Dec 26, 2005 09:51 PM
a1320addict
Apr 17, 2005 09:20 PM
-Bionic-
Apr 23, 2004 05:46 AM
integsra
Jun 25, 2001 06:48 AM
