problems on my build
Old May 7, 2009 | 11:35 AM
ZCSp0ngeR's Avatar
Default problems on my build
i have a b18c1 and block was machined .030 over with Ctr pistons with stock rods and stock crank. when i bolt on the main bearing and torque them to specs the crank turns fine as soon as i bolt the rods and torque them down cyl one and two rods have no side to side play in them, and the crank is hard to turn, so my first question is main bearing caps it torque to 54lbs and the rod bearins is to 26ft lbs ?
Old May 7, 2009 | 11:40 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: problems on my build
Ok, Here you go.
http://www.http://www.**************...94Integra-FSM/
The **** stuff is r e d p e p p e r r a c i n g all one word. This Vboard is BS.
Old May 11, 2009 | 04:59 PM
ZCSp0ngeR's Avatar
Bump!!!
Old May 11, 2009 | 05:08 PM
DonF's Avatar
No1 ,all the mains do not go to 54 on that bloc. No2 When you had the rods reconditioned did they check squareness, big end to little end? No3 what size did you have the big end of the rod, done to when they remachined them for the ARPs?
Kid-jdm-teggy
Engine Machining & Assembly
Jul 22, 2015 11:27 AM
trueracer98
Jan 23, 2012 04:49 PM
em1kiddo
Dec 24, 2011 02:22 PM
salyboy25
Sep 4, 2011 05:01 PM
Guru Designs
Jul 8, 2004 09:50 AM
