EF Foglight install.
Old May 7, 2009 | 11:32 AM
Cole89ef's Avatar
Default EF Foglight install.
I was wondering if someone had done a write up on how to install the advanced auto fogs, the ones that look like the JDM ones on a hatch front bumper? If so can someone post a link?
If it hasn't been done, does anyone know how, or have any advice? How far are they supposed to be below the bumper lights?
Thanks for the help, if there isn't a write up I will make one with pics this weekend.
Old May 7, 2009 | 11:41 AM
exz0n-.-'s Avatar
Default Re: EF Foglight install.
take the bumper off, there is templates on the backside for the oem ones.
Old May 7, 2009 | 12:32 PM
Cole89ef's Avatar
What should I use to cut it?
Old May 7, 2009 | 12:35 PM
xalents23's Avatar
A dremel works well with the cutting attachment.
Old May 7, 2009 | 12:44 PM
Cole89ef's Avatar
Just the cutting wheel? Won't that melt the plastic?
Old May 7, 2009 | 12:47 PM
92teginsc's Avatar
dont mess up your bumper by cutting into it if you dont know what youre doing. take it somewhere!
Old May 7, 2009 | 01:25 PM
Cole89ef's Avatar
What, so they can cut it with a dremel? No thanks.
Just be careful and take it slow, I was just wondering if dremel had a specific plastic cutting bit.
Old May 7, 2009 | 01:56 PM
mpower325's Avatar
what fog lights are these? does any one have a pic
Old May 7, 2009 | 02:31 PM
92teginsc's Avatar
well you was the one that was worried about it so much!
Old May 7, 2009 | 02:33 PM
Eighty-Nyne's Avatar
Cut out the center with the cutting attachment...then grind out the edges with the rotary grind attachment...do quick swipes so you don't build up heat...and take your time...
Old May 7, 2009 | 05:19 PM
Cole89ef's Avatar
Got the lights all wired up.
And got the pass side hole cut and sanded down, but the babies sleeping now so I can't do the drivers side until morning. Will post pics tomorrow night.
Old May 7, 2009 | 08:03 PM
jhammond_82's Avatar
Reject Papi
yeah, i'm in for pics of this.
Old May 7, 2009 | 08:09 PM
Radim's Avatar
This is how we did it... take a drill to it.
This one is comparing autozone fogs which are pretty common to the better 89 Prelude fogs that i used.
Old May 7, 2009 | 08:55 PM
Cole89ef's Avatar
Wow, that looks like a rush job from the work pics, but looks clean all finished.
How much bigger did you make the holes than the actual fogs? Mine are a pretty tight fit. Any close ups?
Old May 7, 2009 | 09:39 PM
EJ1_Sleeper's Avatar
damn the 89 lude fogs look good on the bumper. ive got the advance ones and was just gona drill a hole to mount the light to the bumper (not cut the bumper all the way out). I may just go ahead and try this when ive got some time to mess with it.
Old May 7, 2009 | 09:47 PM
~sp33~'s Avatar
EFB055
Something sharp.
Old May 7, 2009 | 10:41 PM
TeamRedline89Hatch's Avatar
Nice, I installed some of the Prelude fogs too. How did you mount them? To the bumper?
Old May 7, 2009 | 11:00 PM
crx_si-r's Avatar
when i used to have the prelude lights i drilled a hole into the bumper support.
Old May 7, 2009 | 11:30 PM
~sp33~'s Avatar
EFB055
Made a bracket that bolted behind the bumper support.
Old May 8, 2009 | 05:03 AM
Radim's Avatar
Yep, Modified the bumper, the hole for the fogs isn't much bigger than the fog it's a really tight fit.. in the pic it doesn't have the bracket bolted up it's just being held in by the bumper.
Looks better with the fog covers on, in the pics the fogs don't have the covers which is why you see a little bit of a gap.
Old May 8, 2009 | 05:09 AM
Reject Papi
that actually doesn't look too bad. who else other than you knows that they aren't the real jdm thing? lol, noone.
Old May 8, 2009 | 08:31 AM
JAYB90's Avatar
you should buy the oem harness a guy on here makes, he can give you an oem switch to, not those ugly toggle switchs that come with the kit.
im scared to cut into my bumber under the turn signal lights, dont wanna mess up. i might do the grill type deal and bolt it into the front lip holes.
Old May 8, 2009 | 11:42 AM
crx_si-r's Avatar
That would be me
Old May 8, 2009 | 02:33 PM
Radim's Avatar
They are stamped Stanley too,
Old May 8, 2009 | 03:14 PM
jo7man4's Avatar
thats a 88-89 bumper right? do the 90 91 bumper covers have the template in the back too?
