1990 Accord Overheating
Old May 7, 2009 | 10:30 AM
ERT1967's Avatar
Default 1990 Accord Overheating
It overheats in heavy traffic or at long stop lights, the radiator filled the reservoir. What could cause this? I replaced the thermostat and fan sensors last year with Honda parts.
Old May 7, 2009 | 11:53 AM
dafang's Avatar
Default Re: 1990 Accord Overheating
Replace the thermostat with 180 degree one rather than the 195 degree original equipment stat.
Since you are in Orlando you do not need to worry about getting a lot of heat in the winter.
Old May 7, 2009 | 12:45 PM
Bad_dude's Avatar
Is the fan working?
Old May 7, 2009 | 06:14 PM
ERT1967's Avatar
Both fans do work but dosent the a/c fan only turn on when the a/c is being used.
Old May 7, 2009 | 07:28 PM
HONDASEABEE's Avatar
New User
have you bleed your system there should be a presure nut next to the hose in the rear just open it while the engine is on and you should close the nut when a full stream on antifreez comes out this worked for meee..
Old May 7, 2009 | 07:33 PM
New User
I need help also trying to install a OBX pulley kit on my 95 accord ex 2.2l i figured out how to get the power steering of but the alternator is killing me..any ideas.mine was just to take it off and have a alternator shop do it is this the easyest??
Old May 7, 2009 | 08:56 PM
ERT1967's Avatar
Removing the alternator is a pain, I can only use open end wrench to take it off. They sell sockets for that but it isn't cheap.
Joseph DiNicola
Feb 29, 2016 04:58 PM
mr.mightyone
Feb 24, 2015 08:05 PM
galt88
Aug 23, 2012 02:36 PM
tsouyporta
Sep 17, 2006 07:02 AM
swtpc6800
Mar 20, 2005 04:32 PM
