What's that Vacuum sound?
Old May 7, 2009 | 08:50 AM
Tyme2Breathe's Avatar
Default What's that Vacuum sound?
(97' Civic EX) My car makes a strange vacuum noise and it is coming from the power steering pump area, I just now finished installing a new power steering pump but hear the sound still. Has anyone encountered this and can they explain?
Old May 7, 2009 | 09:32 AM
Jimster480's Avatar
Default Re: What's that Vacuum sound?
what do you mean by a vacuum sound? like a whining? is your line clogged or did you not use the honda power steering fluid?
Old May 7, 2009 | 09:40 AM
like a a high pitched whining, vacuum grinding like sound...yes, I made sure to use the honda power steering fluid, I actually just checked the car again and the noise seems to come in and out, higher lower or not audible at times
Old May 7, 2009 | 06:29 PM
z6hatchboy's Avatar
may need to bleed it?
Old May 7, 2009 | 06:32 PM
civic_driver's Avatar
Maybe the belts are on too tight?
Old May 7, 2009 | 06:52 PM
hOnda_hiEn's Avatar
x2
Old May 7, 2009 | 08:28 PM
PhatFactory's Avatar
You might have air in the system, top the fluid off and turn the steering wheel side to side (all the way left and right, untill u see no air bubbles in the resovior). If you dont have enough PS fluid or if there is a leak( even a lil) its will make that noise. Good luck.
Old May 7, 2009 | 09:02 PM
98civdx's Avatar
Master Detailer
this my guess.
CheezeFrog
Nov 18, 2019 11:11 PM
Honda4Lifex
Jan 27, 2019 01:11 PM
sky9
Feb 25, 2011 02:40 PM
questseek
Mar 6, 2010 09:32 PM
Inextricabledrvr
Mar 18, 2009 07:56 PM
