Whats the maximum rev I can run SAFELY on ITR motor
Hi guys,
I have a JDM ITR block with some PCT pistons in them. I have ARP rod bolts on the rods for insurance. Then I have a b16a head which is fully built with 5 angle valve job, port and polish and full ferrea valvetrain. The head is supposed to handle up to 10k RPM without a problem. I am about to get some Skunk2 Pro2 cams and wanted to rev the car to 9500. Can the ITR block handle that RPM safely? What would i have to do to rev there safely?
With a built & ported head and stage 2 cams... I could see making power up to 9500...
Stock type Rs can go to 8600... Dont know why someone would upgrade their whole head and be satisfied with that...
But yea its all about dyno time... Put it on the rollers and tune it to maximize your upgrades... And the block will hold up fine...
Also might wanna look into a top of the line header... Thats also gonna contribute alot to making power high up...
I think the op was wanting to know if it would be a good idea to push his engine to 9500... not if he will make power to 9500.... btw yes you can but to add extra insurance I would use arp con rod bolts to ease the mind!!
greenDC2
Jun 25, 2004 06:57 PM
