single cam problems
same problem with me, just did a mini me vtec swap and timing is off by one tooth.
tomorrow will retime it and im using a P06 ecu with a oxygen censor CEL.
my P28 burned out and will need another one of tho.
did it just start doing that out of no where or did you do some kinda swap? if you did some kindsa swap then chances are you have your spark plug wires out of place. they probally arent the same firing order as your other motor.
91integraLSVTEC
Jan 14, 2009 11:08 AM
