OEM Exhaust Piping swaps
Alright im just wondering if theres any OEM stock exhausts with a larger diameter that would fit on my EJ coupe, i got a d16z6 with a DC 4-1 header
okay cool.
hmm, OEM exhausts...
If there's a bigger one, the only one it is is the 99-00 Si exhaust. However, the so-called "size difference" I have heard that the Si has may only be a rumor.
If the 99-00 Si isn't bigger (since i'm not sure), then nope, there's nothing OEM that is bigger than what you have (that will fit).
EDIT: nope, Si is the same size. So no, there aren't any direct-swap OEM exhausts that will fit that are bigger than what you have.
damn that sucks, well i just need a whole new stock exhaust set up because having a gutted cat with no turbo/nitrous sucks. I need some back pressure with NA thanks though
