Do strut bar/strut braces really make a difference
Just wondering if adding a strut bars really make a difference? Are they even worth it to invest in? Are they over rated?
very well worth it if you buy a well designed brace. think of a sky scraper without braces, its going to sway and be unstable. are those braces in there over rated? do those make a difference? *not being sarcastic* strut bars are excellent as long as youre not buying the ones off ebay... ive bought a couple just testing to see what works, and snapped 3 ebay front uppers. just remember though, there is such thing as a chassis being too tight. id definitely recommend a front upper rear upper and good sway bars.
Yes, it's worth it. I had massive chassis bendage going on small ramps at an angle and I guess my chassis lets water leak now. I heard squeaking and thought it was my suspensions. I threw one on and the squeaking went down dramatically. I'm going to weld the hinges tomorrow and see what happens then.
those are 2 good ones... ive got my factory em1 bar up front, a skunk2 rear lower tie bar and im trying to locate some good sway bars...well more or less locate the funding for better sway bars, definitely been wanting to try out the Tripod bar. i wouldnt go crazy with braces though, like the H brace and all these random bars... and a C Pillar bar!? are they serious!? the pillars are already the most structurally sound points in a car, and ive seen no proven results from bracing two points like that together. just my .02
The C-pillar bar is more of a benefit for the hatches than the coupes/sedans.
Strut bars work great. They're good bang for your buck upgrades. Buy good quality bars with no flex in them. Here's a nice setup for you to roll on, assuming you've already lowered your car:
3 point front upper
4 point rear upper (pwJDM makes it for coupes and hatches)
Front lower H-brace (NRG makes one with excellent ground clearance)
And I would buy all of these at the same time, because they work in conjunction. If you can only afford one, get the tie bar. Don't get a sway bar without the subframe brace
1) rear lower tie bar (Suspension Techniques makes a one piece tie bar/subframe brace)
2) rear subframe brace (ASR make a good one)
3) rear swaybar (JDM ITR, ASR, Suspension Techniques are all good)
I'll also second the rear trailing arm bushings. Get a kit with spherical bearings from Blox or pwJDM. Add a stiffer front sway if you think you need it, and you're good to go.
3 point front upper
Also, yes traction bars work well; you can use those instead of a front lower tie bar or H-brace.
i broke an ebay front upper about 5/8 of the way towards the driver side
but that was because i dropped my *drink* on my lap and a street divider came out of nowhere; hitting my oil pan (cracking it squirting oil everywhere), thus the engine coming all the way up through the strut bar snapping it and making a dent in my hood; also braking my left torque mount bracket.
No seriously though drinking and driving is NOTTTT COOOL
Blaming the strut bar for its own breakage would be like calling your front bumper a piece of **** for breaking in a front-end collision, or calling your tire crappy for losing air when you run over a nail.
are you f*cking serious?? ill get some pics if i can find one of them still... have you never seen cheap crapo ebay parts in an autocross???? they dont last long. most people are morons and leave them loose on the car and it completely defeats the purpose. if you put the uppers on loose, and then turn the bar until its tight, then it stiffens the chassis. try that with a cheap chinese cast aluminum ebay bar.. and you can call BS all you want, just because you cant figure out how to drive hard enough to snap one doesnt mean its impossible. GO TO AN AUTOCROSS
HaHaHaHaHaHa
Brand has NOTHING to do with it, Skunk2 makes some shitty *** strut bars with hinges. Tein also makes shitty bars.
Go for ONE piece bar, I dont care if it cost $10000 or if your neighbor made it, ONE PIECE is the key.
-OEM Si/GSR (Really cheap, I got mine or $20 on CL)
-Neuspeed
-Mugen (the legit one)
-PW:JDM
-Carbing
-Benen
-Neuspeed
-PW:JDM
-Carbing
-Benen
-Neuspeed
-PW:JDM
-Carbing
-Benen
-Neuspeed
-PW:JDM
-Carbing
-Benen
BLUEBOMBER... ive never messed with a front lower H brace... what mounting location does it have? and how exactly does it stiffen? it may be something i need to look into getting. just curious
It didnt clear my 4-2-1 header so I gave it away.
-Neuspeed
-PW:JDM
-Carbing
-Benen
-Neuspeed
-PW:JDM
-Carbing
-Benen
Si/GSR bars can be had for like $30 used, making them the best value
http://bluebomber.com/car/ej/DSC01547.JPG
It basically cleaned up the slop in the front end for me. It made turns tighter and more responsive. I paid 50 bucks for the NRG one and it was well-spent. I'd get another one but I have traction bars now.
I'd still like to see some pics of that broken bar too...
Here's a pic of it when it was on my ride:
seems like it would also protect part of the suspension and stuff under there if you were to scrape or bottom out
