Pressure sensor on condensor
Old May 6, 2009 | 07:49 PM
nmhuntr's Avatar
Default Pressure sensor on condensor
Does anyone know if you can replace the pressure sensor on the condensor without loosing the FREON?
Thanks
Old May 7, 2009 | 06:16 PM
nmhuntr's Avatar
Default Re: Pressure sensor on condensor
btt
Old May 9, 2009 | 05:31 PM
nmhuntr's Avatar
Well since no one here knows anything about the pressure switch I will now tell you from my lesson learned.
The pressure switch on the condensor is the high pressure switch and prior to removel the system must be drained of freon. The switch on the low pressure side does have a valve that closes upon removal so it can be removed without loosing freon.
Hope this might help soneone else
gs_rbaby
Jun 1, 2023 04:05 PM
Delslowman87
Apr 27, 2020 03:08 PM
Freedo_Civegra
15
Jun 1, 2018 09:10 AM
hall97civic
May 24, 2015 12:54 PM
powerflow
Aug 28, 2009 11:16 AM
