How to clean coolant passages and cylinders
Old May 6, 2009 | 03:02 PM
holsetcivic's Avatar
Default How to clean coolant passages and cylinders
hi everyone, i just got this civic dx with a blown headgasket.
i pulled the head off and noticed stray pieces of old headgasket in the coolant passages around the cylinders. also when i removed the water pump theres a nasty green slime sitting in the opening. what the best way to clean out the coolant passages in the block? soap and water?
should i also put soap and water in the cylinders to clean the cylinder walls, then just turn the motor over to pump the water out?
any advice would be greatly apprecieted
Old May 6, 2009 | 04:50 PM
stevenDAtegra's Avatar
Default Re: How to clean coolant passages and cylinders
You can buy a coolant flush kit I believe. Soap and water doesn't sound too good with the cylinders though. Try maybe using a magnet to get the headgasket pieces out.
Old May 6, 2009 | 07:30 PM
jlude90's Avatar
coolant flush won't help that
a magnet might, and don't touch the cylinder walls, why would you think they need to be cleaned? are the deposits or build up?
Yao Saechao
Mar 26, 2018 01:25 AM
Barmaleyka
Acura TL, RL & ZDX
Jun 4, 2017 09:13 AM
91akira
Jan 31, 2014 07:36 AM
raider1qaz
14
Feb 9, 2013 09:12 PM
raene
Mar 1, 2003 05:06 PM
