Adding tranny fluid!!!
Old May 6, 2009 | 12:59 PM
sublimeh215's Avatar
Default Adding tranny fluid!!!
I have a b18a1 in my ef with a b16 tranny...
When my axle went out 2 weeks ago i had a leak..
Does anyone know how to add tranny fluid into my tranny???
Old May 6, 2009 | 01:21 PM
crash232's Avatar
Default Re: Adding tranny fluid!!!
there should be a large round metal plug located above the axle that you can take off with a 1/2 inch driver.
Old May 6, 2009 | 01:29 PM
nico91civic's Avatar
you can also unbolt the vss and fill from there but its a little harder to get the amount right, should be filled to the bottom of the hole for the big plug previously mentioned
Old May 6, 2009 | 02:27 PM
FOMULA91's Avatar
from the VSS is the way... I'll just drain the whole thing and refill it....
Old May 6, 2009 | 02:28 PM
4drEF's Avatar
Keyboard Humorist
Please don't put tranny fluid in your manual transmission.
Add oil.
Old May 6, 2009 | 02:30 PM
stevenDAtegra's Avatar
Honda MTF or GM Syncromesh FM is the way to go
Old May 7, 2009 | 06:11 AM
mjfubar101's Avatar
Add oil.
What he said, I like to use synthetic, same stuff you put in your motor.
Old May 7, 2009 | 06:15 AM
crxblues's Avatar
honda mtf only. dont mess with the sycromesh unless ur tranny is effed. most tranny grinds can be solved with just replacing tranny fluid with honda mtf. easiest way to fill is through the reverse light switch. takes a little under 2 quarts i think
Old May 7, 2009 | 06:17 AM
isn't the reverse light switch much lower than the actual fill point how could you fill it to the proper level there?
Old May 7, 2009 | 06:21 AM
ek_bape's Avatar
I remember finding a thread on here on how to put tranny fluid in. I searched in google but I can't find it now.
Old May 7, 2009 | 06:37 AM
mjfubar101's Avatar
It is simple get under the car and unbolt the one bolt and fill using a pump or long hose and a funnel post a pic of the tranny and we can tell you exactly where if you want.
Old May 7, 2009 | 07:05 AM
crxblues's Avatar
its right on the top of the tranny has a rubber boot with two wires coming from it. its alot easier than your making it
em12nv
Feb 9, 2008 01:49 PM
fukaintmuven
Nov 19, 2002 08:05 PM
pelotudo
Jul 21, 2002 02:33 AM
wizzards581
Apr 5, 2002 10:20 AM
