Super D!!!!
well i wasnt so much referring to you as colins build :p hell the d18 stroker on D is going strong as hell, you should see the power and torque curve of that bitch.
Thanks for responding! I need is a little more information on this article:
http://www.hondatuningmagazine.com/t...6a6/index.html
Something like step by step, the forum or if someone has already done
Thank you
Thank you
D series make more NA power if you lower the compression... Just use a dremel to grind off the piston domes to make a dish piston. port and polish you factory header.. should net 200whpzzzzz
allowing any modifications to the engine and the body of the car, I am currently running a D16Z6, stock internals!
well if it allows and mods why not boost it or swap it? Or build a D18 like what i told you to look up. The torque on that thing will be ridiculous, your basically running a near 95mm stroke and a sleeved motor can go up to 78mm no problem. Talk about power and torque
