are the rear brake lines from a 94-01 integra the vsame as 99-00 si?
Old May 6, 2009 | 06:16 AM
elnoyl's Avatar
Default are the rear brake lines from a 94-01 integra the vsame as 99-00 si?
are the calipers the same? Are the brake line mounting points the same?
Old May 6, 2009 | 07:00 AM
thumper64's Avatar
Default Re: are the rear brake lines from a 94-01 integra the vsame as 99-00 si?
Yes, they are the same lines. Stoptech lists part number 950.40500 for both the 94-01 Teg and 99-00 Si. Honda lists it as the same part also.
Old May 6, 2009 | 07:07 AM
elnoyl's Avatar
ok so what's the difference between the front calipers on an integra compared to the front calipers on an 99-00 civic si
Old May 6, 2009 | 05:12 PM
redflaredcrx90's Avatar
there the same
Old May 6, 2009 | 05:38 PM
elnoyl's Avatar
i was reading that the calipers on the 99-00 si are the same for the rears. I heard that the brake lines on the integras have 2 mounting holes whereas the si ones have only 1 mounting hole is that correct? so if your using si trailing arms get the si brake lines and if your using the integra trailing arms get the integra brake lines is that right? what stainless braided lines are the ones to get?
01geeser
10
Mar 26, 2007 05:05 PM
jolt-tsp
Sep 22, 2003 11:46 AM
