zc dohc help plz!
Old May 6, 2009 | 03:32 AM
minime-dom's Avatar
Default zc dohc help plz!
ok i got every thing done and its throwing a code 9 and that is cps but i had a buddy to come over and look at it and he said that i had a burnt valve and thats why am throwing this code could this be or no cause of the way it sounded starting up n the way it sounded on ?
Old May 6, 2009 | 06:08 AM
sean burke's Avatar
Default Re: zc dohc help plz!
Did you pin the ecu corectly for the cyl. pos. sensor? How did it sound when you started it up?
Old May 6, 2009 | 03:45 PM
minime-dom's Avatar
what u mean , put the plugs in rite? , well when it starts up it sounds really rough n wants to shut off, i dont even know if the sensor is pluged into the ecu but its pluged up , up front near the dizzy
Old May 6, 2009 | 04:16 PM
sean burke's Avatar
I had a similar problem with my zc when I put it in. I took the valve cover off and noticed 3 stuck intake valves. Engine has approx 50,000 miles. The machine shop said that the intake valves had this strange black(no, it's not carbon) stuff that was making them stick. your description sounds excactly what happened to me (provided your wiring conversion is right). Pull your valve cover and find out. Also check your valve timing.
Old May 7, 2009 | 06:11 AM
minime-dom's Avatar
hmmmmm so u think i should just take off my head and send it to the machine shop?
Old May 7, 2009 | 06:30 AM
sean burke's Avatar
don't pull the head until you examine the the valves. Look over where the valve rocker meets the camshafts. If anything is wrong, it should be pretty apparent. and check the camshaft timming, ZC's are notorious for being off by a tooth or two.
Old May 7, 2009 | 11:38 AM
minime-dom's Avatar
i took the valve cover off every thing looked good
Old May 7, 2009 | 07:23 PM
sean burke's Avatar
Did you check the valve timing? At top dead center( when the single crank pulley notch is lined up with the pointer on the cover, this can be hard to see without taking the alternator belt off). The up arrows on both camshafts should be at the 12:00 position, the inner notches of the cam sprocket should face eachother and be level with the mating surface of the valve cover, the outer notches should be one tooth above the valve cover mating surface.
Old May 7, 2009 | 07:26 PM
hellraiser7492's Avatar
zc's are a b!tch to time dude. it's horrible. they always get knocked off a tooth regardless.
Old May 8, 2009 | 01:49 PM
minime-dom's Avatar
damn yeah its off a tooth and i maybe of bent a vavle o well **** it ill take the head off n send it to a machine shop
Old May 8, 2009 | 05:11 PM
we timed it like it said and it looked like it was off from the pulley..
we put it it in anyway and the timing belt was correct
i ****ing hate zc motors.
should of gone d16a6..
Old May 8, 2009 | 11:12 PM
~sp33~'s Avatar
EFB055
Your not going to bend a valve if it's only off one tooth.
Old May 9, 2009 | 05:46 AM
really?
well that's good to know.
Old May 9, 2009 | 10:30 AM
minime-dom's Avatar
yea i took the head off and nuthing was wroung just my head gasket is messed up
WindyCity
Mar 29, 2007 07:28 PM
DevineCRX
Jul 29, 2003 06:07 PM
CimorelliCRX
Mar 8, 2002 05:35 PM
