Vtec wiring..???
I have a type r motor, but I have a obd1 harness. I am using the jumper conversion to my obd2a jdm ecu p73, but there is no Vtec. So what wire i am missing????? helpp And my rev limiter stops at 7 k...that really suckss
i have a 97 jdm itr wire harness..... pm me offer IF intrested
Check the pinout for your conversion harness. It's literally as simple as connecting the one pin to the correct place. It isnt a harness issue, because I have an ITR engine in an OBD0 prelude.
more than likely your conversion harness will not have a pin there for the vtec solenoid, so just add a pin there and run a wire to the solenoid...if there is a pin there, you might have to trace it down.
91 DA B18B1
Mar 25, 2011 08:15 AM
anadonJ
Oct 11, 2009 12:52 PM
7808
Oct 21, 2008 12:40 PM
Sci_v_icI
Apr 1, 2006 04:53 PM
