Why my rev limiter is at 7k??? w/ no VTEC!
Old May 5, 2009 | 10:38 PM
Fastasscar's Avatar
Default Why my rev limiter is at 7k??? w/ no VTEC!
I have a 95 acura integra ls special edition. It has a jdm type r complete change over, beside the wiring harness. jdm p73 ecu with the jumper. My rev limiter is at 7k and no vtec at all? Somebody help me!!! I am a new honda owner, so help....
Old May 5, 2009 | 11:12 PM
civicexowner's Avatar
Default Re: Why my rev limiter is at 7k??? w/ no VTEC!
are u sure it is a type r motor... maybe you got scammed.
Old May 5, 2009 | 11:32 PM
Fastasscar's Avatar
Yes I am sure.... Because I bought it!
Old May 5, 2009 | 11:36 PM
racebum's Avatar
sounds like your vtec isn't working. 7k is about where the primary lobe falls apart & won't pull any higher. i accidently forgot to completely plug in the solenoid once and had the same thing happen. the fact it didn't jump hard at 5700 was my first clue.
Fastasscar's Avatar
And yes the JDM p73 ecu is real!
Old May 5, 2009 | 11:42 PM
racebum's Avatar
could be a wiring issue. that ecu is plug and play in a gsr. with an ls or rs you have a few things to re wire
Old May 5, 2009 | 11:43 PM
Fastasscar's Avatar
I checked and the vtec soleniod is plug in, but I don't feel the vtec kick in at all and the worst is that it only revs up to 7k and it drops... The jumper conversion is brand spanking new... obd1 to obd2a...
Old May 5, 2009 | 11:45 PM
Fastasscar's Avatar
Wiring issue?? any tips?
racebum's Avatar
Originally Posted by Fastasscar
I checked and the vtec soleniod is plug in, but I don't feel the vtec kick in at all and the worst is that it only revs up to 7k and it drops... The jumper conversion is brand spanking new... obd2a to obd1
? the jdm itr ecu is obd2, what in the world do you have going on?
i have that same setup, a jdm itr swap with a p73-003 ecu, it's obd2 and a direct plug in a 96-99 GSR harness
Old May 5, 2009 | 11:48 PM
Fastasscar's Avatar
My bad I made a mistake.. is obd1 to obd2a..
Old May 5, 2009 | 11:55 PM
racebum's Avatar
did you add the vtec wires in your car and to the right pin out in your ecu?
vtec gotta hit hard yo
Old May 6, 2009 | 12:54 AM
Fastasscar's Avatar
does anybody has the p73 pin out diagram? I just want to make sure what wire do I connect to what? To make my car rev normal and my vtec working condition. helppp
Old May 6, 2009 | 01:36 AM
racebum's Avatar
look up instructions on the apexi vafc2 the pinout is shown there. also try googling things like vtec obd2 pin out, gsr pin out, type r pin etc..
Old May 6, 2009 | 10:55 AM
hmoobhero's Avatar
i'm guessing you're using the ls engine harness, so you're gonna have to wire the vtec into the ecu harness. thats prob gonna solve the no vtec thing.
but with the redline at 7k w/the itr ecu...i'm stumped...
also, did you do the swap? if not take it back to the shop that did it and make them fix it...
Old May 6, 2009 | 11:22 AM
jdm_bones's Avatar
You answered your own question in your post, it the wiring, you didn't pin the two vtec wires, and knock sensor.
Old May 6, 2009 | 11:37 AM
racebum's Avatar
don't be. 7k is about where it feels like you have a redline if vtec doesn't hit hard yo
the primary lobe isn't to support rpm past that point.
Old May 6, 2009 | 01:44 PM
fingers-vtec's Avatar
i had the same problem on my jdm integra when i imported it, turned out there was a delimiter on it which was broke and causing it to limit!
Old May 6, 2009 | 04:55 PM
racebum's Avatar
like in the ecu? how strange. if the vtec lobes don't kick there isn't like a cut off limit. the engine just doesn't wanna pull past 7k. this is the first i've heard of a delimiter, what happened ?
Old May 6, 2009 | 05:00 PM
Odom's Avatar
is it throwing any CEL?
Old May 6, 2009 | 10:21 PM
exactly as above would not let the vtec kick in at 6200 then i would hit the redline around 7, now im hitting my redline around 9200
Old May 6, 2009 | 10:33 PM
racebum's Avatar
your tach is off. vtec hits at 5700-5800 and the rev limiter completely cuts it off by 8700
Old May 6, 2009 | 10:58 PM
Fastasscar's Avatar
I am going to rewire the solenoid.. So let see whats going to happen from there.. but the 7k limiter trips me out????
Old May 6, 2009 | 11:25 PM
racebum's Avatar
get everything working right before you let something trip you out.
Old May 7, 2009 | 09:01 AM
anybody know an easy way to check there tach is working properly my itr revs to around 9200
Old May 7, 2009 | 11:01 AM
hmoobhero's Avatar
if you're using a stock itr ecu then redline is at 8400. if you go past that 1) your ecu is chipped 2) your tach is broken.
also, where does your car idle at(when warmed up)? if anything over 1k rpm then probably its your tach...
