HUGE power loss with AC on Civic
Ok so I have a 98 Civic Ex, I know that when using AC on this car I should expect some power loss. Well my car suffers a Huge noticeable power loss when I turn on the AC. The power loss seems to go on and off very consistently. I know it's not because the car just doesn't have enough power because I just installed a turbo kit and same problem. The car's power is cut in half and very annoying when it comes and goes. If you guys have any ideas please let me know. Thanks in advance for any help!!!
It's a stock y8, I just replaced the battery and the alternator was my next thing that I was thinking about, but wasn't sure if that would be a cause.
having your engine bay look cooler and car lighter is not worth the soaking wet t-shirt while driving in triple digit heat...that's my opinion.
lol guys hating on the A/C (not you, OP)... it doesn't take that much power, and if you're DD'ing it you barely even notice.
OP, if you notice that it's more power loss than normal, have an A/C inspection done.
Your kidding right? A/C on a d series engine absolutely kills the horsepower; not that d series engines have much power to begin with which really drives home my pervious statement. Take a 100hp engine, take away 10-12hp and that is a huge difference.
If you want that extra power, turn off the A/C for the moment being. It doesn't take enough power when the compressor clutch is disengaged for it to be worth removing, unless you just want the extra space in the engine bay and to save some weight, or if you're not DD'ing the car.
Since we're on the subject of D's with AC:
On my DD, (99 CX) occasionally at a stoplight/sign it will surge, and rev up,down,up,down like a vac leak. Any ideas?
Car was wrecked a while back and AC has since been fixed,recharged,etc.
It's not so much surging, but idle will drop like about 1k and power will be cut like in half for about 1 min or less and then go back to normal. That will repeat the whole time the ac is on, even on the freeway. It's a day and night difference.
