Honda S2000 Honda S2000
Help, I think my front end is going.
Old May 5, 2009 | 09:43 PM
ryan8624's Avatar
Default Help, I think my front end is going.
I have been noticing the front end of my car feeling very loose lately and it will pull intermittently (ball joints?). It has about 92K on it so it wouldn't be surprising except that it came on so fast. I was a track day a few weeks ago though that might have loosened it up. So my question is, is there a particular week spot on S2000s that I should be looking for? I will go through it like any other car but if someone with more experience can point me int he right direction that would be awesome. I have only owned the car for about 7 months, 5 of which were in storage so I am still learning about it. If it makes a difference the car is lowered on Skunk2 springs.
Old May 6, 2009 | 08:41 AM
Black S2K's Avatar
Default Re: Help, I think my front end is going.
nothing comes too mind. just go over everthing twice and make sure everything is ok and if somehting is loose after u tighten it mak sure to get it realigned again that could have been ur problem i the first place. the s is pretty sensative to diff allignment specs so if somehting is out of wack the car will feel like poop.
Old May 6, 2009 | 12:25 PM
White Smoke's Avatar
i my honda
Global Mod
Has it been aligned recently? Since you owned it?
Old May 6, 2009 | 04:46 PM
ryan8624's Avatar
No, but it was aligned with my Enkies on, and I put the stock wheels on for a track day. Haven't switched them yet. So the S is just really sensitive to issues like this?
Old May 6, 2009 | 10:04 PM
5 Skware's Avatar
I missed the boat
Yes, it is very sensitive to changes.
Old May 7, 2009 | 09:47 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Did you clock the bushings when you lowered the car? It seems like people have trouble with control arm bushings around this mileage. If you didn't clock the bushings and they're old and weathered from being in MN weather, then you may have torn or weakened one.
I doubt that. You had the stock wheels on at a track day. Meaning that you drove the hell out of it and you would have noticed any looseness more so than on the street.
If you think your ball joints are bad, just yank on the wheel while the car is on the ground (upper ball joint) and then jack the car up and yank on the wheel in different directions some more to see if it moves. Give it a little punch on the tire to see if it shakes or rattles excessively.
If you put your hands at 9 O clock and 3 O clock on the wheel and pull side to side, you're testing tie rods.
12 and 6 O clock and you're testing ball joints.
This would take less time than posting the question.
You can also visually check your bushings.
Your alignment may have also slipped at the track. So have it checked again if everything else checks out good.
Also check your tires to make sure one isn't low or damaged. Not sure why nobody mentioned tires.
Not that sensitive.
Old May 7, 2009 | 10:11 AM
Black S2K's Avatar
^ this guys is just a bundle a good info
Old May 7, 2009 | 07:47 PM
Slammedsilverstone's Avatar
catch it!
F20B_accord
Sep 7, 2010 05:16 PM
Insolent
Sep 23, 2009 02:59 PM
Boner_Ben
May 26, 2009 06:53 PM
foxjaeger
Mar 12, 2009 09:31 AM
tomato_man
Apr 17, 2007 11:03 PM
