integra running poorly when guages go crazy
anyone ever heard of this? my tach and speedometer just go nuts randomly. it makes the car run extremely poorly. i have NO CLUE what else it could be.... i have no CELs. i put the motor in this winter and im still working to get it running right. i have a brand spanking new: coil, cap, rotor, o2 sensor, and still nothing. its getting a little expensive to keep playing guessing games. if anyone could help that would be awesome
my gauges went crazy when my remote starter began messing with all my eletricals. do you have remote start or any non-factory electronics?
https://honda-tech.com/forums/acura-integra-6/computer-electrical-failure-traced-remote-starter-2564855/
i removed everything the first owner had in it; guages, shift lift, etc. i have an ecu that is chipped for 450's and it still would not run right...
UPDATE: replace the igniter today with a brand new one, now it backfires out the intake
timing belt is dead on, all grounds are there/// im about to give..
When my car was on the dyno, the tach was moving erratically. Checked everything and finally replaced the plugs. All good after that. Try swapping that out first.
