Wheel size
^ That depends on your definition of "fit." That is an aggressive fitment and will require some camber adjustment. To some that is perfect, to others it may be too much. If you want it to fit like "stock" then that's not the setup for you.
stock height u shouldnt have a problem. when u lower it, ull probably should go coils so u can mess around with height settings, and u will need a camber kit to make them fit. also depends on ur tire size.
CoryTurner
19
Sep 11, 2004 09:31 AM
