99 Civic Si A/C stopped blowing cold
Old May 5, 2009 | 04:43 PM
Frenchy1337's Avatar
Default 99 Civic Si A/C stopped blowing cold
So today my A/C stopped blowing cold. From what it looks like its not the compressor as I wired it straight to the battery and it works and blows cold air. What could it be? The climate control not working? Any suggestion on what to check?
Old May 5, 2009 | 04:50 PM
sayyoooon's Avatar
Default Re: 99 Civic Si A/C stopped blowing cold
Have you recharged it?
Old May 5, 2009 | 04:53 PM
of course. Like I said when I plug the compressor straight to the battery everything works great. Im thinking its a wiring problem...but where?
Old May 5, 2009 | 05:23 PM
the compressor is not kicking in when press the A/C button, but when I wire the compressor straight to the car's battery it works fine and kicks in. So I know that the compressor is good and that the freon is there as I checked.
Old May 5, 2009 | 06:31 PM
SubieDude's Avatar
Maybe check fuses. Or even a A/C pressure switch thats gone bad? If you haven't messed with anything out of the ordinary i don't think the wiring would just go bad like that. Unless you've got a mouse infestation.
Old May 5, 2009 | 06:34 PM
Well I was thinking maybe the climate control is going bad since also the blower only works on high setting. Not sure though. I didn't mess with the A/C and also checked the plugs by the condenser and everything looks good.
Old May 5, 2009 | 06:36 PM
98civdx's Avatar
Master Detailer
check the resistor in the heater core they go out quite often
try this https://honda-tech.com/forums/tech-misc-15/blower-motors-works-speeds-3-4-but-not-1-2-fix-how-2082345/
Old May 5, 2009 | 06:50 PM
try this https://honda-tech.com/forums/showthread.php?t=2082345
I have tried to replace it and didn't do anything.
Old May 5, 2009 | 06:59 PM
Former User's Avatar
Is fuse 56 or 17 blown?
Old May 5, 2009 | 07:00 PM
I don't think so but I will check again, you are talking about inside the engine bay right? Anything else it could be?
Old May 5, 2009 | 07:02 PM
Fuse 56 is under the hood.
Fuse 17 is under the dash.
There are other possibilities, but this is where to start.
Old May 5, 2009 | 07:19 PM
Fuses are all good. What else can I check?
Old May 5, 2009 | 07:23 PM
Test the compressor clutch relay:
Old May 5, 2009 | 07:36 PM
nevermind, I will try that.
Old May 5, 2009 | 07:42 PM
You'll need a multimeter to test for continuity. You can use a hot wire from the battery as a power source.
Old May 5, 2009 | 07:45 PM
Thank you, I will try that tomorrow morning and let you. Thanks again.
Old May 5, 2009 | 08:27 PM
I know that that compressor clutch does not engage, but does the condenser fan run?
Old May 5, 2009 | 08:37 PM
Yes the condenser fan turns on and runs
Old May 6, 2009 | 08:59 AM
Update: Fixed the issue with the A/C and also found out the issue with the blower motor only blowing on high. There is a bad contact by the condenser where the A/C plugs in. Moved it around and started working again. As for the blow I swapped out the Climate Control from my friends Si and was able to adjust the blower and worked on every settings.
Thanks for the help RonJ@HT
sikvic00
11
May 4, 2011 02:05 PM
gnccracer20
Apr 26, 2009 07:55 PM
Mads505
Aug 29, 2007 11:58 AM
M4
May 13, 2005 06:51 AM
veggiemaster
Sep 28, 2004 08:56 PM
