EF Drag suspension setups
I am curious to know what you guys are running for suspension setups at the strip.
An example would be
KYB Adj
settings
front 2
Rear 4
Spring rates
300
Tire Pressures
20 front
45 Rear
Thanks for any input
I am posting this here so that I only get info from EF guys and its TECH related.
An example would be
KYB Adj
settings
front 2
Rear 4
Spring rates
300
Tire Pressures
20 front
45 Rear
In my sedan we are running Skunk2 drag launches in the rear.. Amazingly enough stock cut springs in the front. With new stock shocks all around.. best 60ft was a 1.80... Always consistant 1.81-1.83.. Going to try a few different setups this year though.. But I cant complain.
I've used KYB AGX's with Skunk2 500lb (front) springs & Eibach ERS 800lb (rear) springs. Settings were 2 (front) and 4 (rear). Best 60ft was a 1.65 on 24.5" M&H slicks. I also used AMR Engineering full coilovers with similar results.
I'm going with wheelie bars now and changed my suspension to a set of custom valved Progress coilovers.
