Which pinout is the horn signal on the SRS connector for steering wheel?
Old Aug 17, 2002 | 08:15 AM
GReddyB18C's Avatar
Default Which pinout is the horn signal on the SRS connector for steering wheel?
Hey everyone,
Like the topic title says. I'm installing a Sparco steering wheel w/Sparco hub in my 94 GS-R. I'm hooking up the horn and it would be easier to run a wire from the SRS connector to the Sparco hub than from somewhere further away.
Thanks.
-Shawn
Old Aug 17, 2002 | 09:27 AM
91vtecripper's Avatar
Default Re: Which pinout is the horn signal on the SRS connector for steering wheel? (GReddyB18C)
Before doing any of that please disconnect the battery. I think that the srs cord is yellow and the horn should have its seperate cord, black.
Old Aug 17, 2002 | 09:37 AM
GReddyB18C's Avatar
Default Re: Which pinout is the horn signal on the SRS connector for steering wheel? (91vtecripper)
The horn wire from the stock steering wheel is a part of the SRS harness from the steering wheel to the SRS connector.
-Shawn
Old Aug 17, 2002 | 10:27 AM
Mike M's Avatar
Founding Member
-Shawn
No its not. the SRS Harness is 2 wires, both being connected to the SRS ECU and Airbag.
Old Aug 17, 2002 | 10:58 AM
GReddyB18C's Avatar
Default Re: Which pinout is the horn signal on the SRS connector for steering wheel? (TypeRmsm)
Hmmm.
When I took the airbag off the steering wheel, the main SRS harness (the ribbon) from the SRS connector (under the steering column) splits off to three separate connectors (inside the steering wheel) that attach to the cruise control switch, horn, and airbag connectors in the steering wheel.
I just need to know which pinout on the SRS connector (under the steering column) is the horn signal. Then I can run a wire from there to the Sparco steering wheel horn contact plate.
-Shawn
Old Aug 17, 2002 | 11:08 AM
D1703's Avatar
in order for the hub to fit you have to remove the white SRS thingy with 3 connectors (its held on by three screws), You are looking for the main SRS yellow plug (under the steering column) and the horn is the one all the way to the left. you can check it with a tester. the horn will come up when its grounded.
Old Aug 17, 2002 | 11:13 AM
GReddyB18C's Avatar
Default Re: Which pinout is the horn signal on the SRS connector for steering wheel? (D1703)
Ahhh.
I've already removed the white piece held on with three screws, and the entire ribbon harness is unplugged from the SRS connector. So the horn is the furthest left pinout on the SRS connector (under the steering column)? I do not have a tester readily available at the moment.
Thanks for your help.
-Shawn
Old Aug 17, 2002 | 11:55 AM
GReddyB18C's Avatar
O.K.,
The pinout all the way to the left is in fact the horn signal (just tested it out). I appreciate all of the help.
-Shawn
Old Aug 17, 2002 | 12:23 PM
jdmhatch's Avatar
Does anyone know if this is the same on the EG's?
Old Aug 17, 2002 | 01:06 PM
GReddyB18C's Avatar
Default Re: Which pinout is the horn signal on the SRS connector for steering wheel? (jdmhatch)
Here's a How-To link for the 5G Civics:
http://hometown.aol.com/llucas7086/5gwheelinstall.html
HTH.
-Shawn
xrblue
May 6, 2018 12:20 PM
Matthew Miller
Jan 29, 2018 03:08 PM
