Auto JDM GSR ECU
Old May 5, 2009 | 02:41 PM
kicksremix2o6's Avatar
Icon6 Auto JDM GSR ECU
sup H-T, im planning to be different and do a GSR or possible LS-V Automatic. is it possible to just plug in a jdm gsr auto ecu to a LS-V setup and make it work fine? i've never heard anyone to do this. let me get you guys input
Old May 5, 2009 | 05:31 PM
94EG8's Avatar
Seagull Management
Default Re: Auto JDM GSR ECU
If you have a '94 - '95 automatic LS teg and use the OBD1 GS-R automatic tranny, ECU and TCU i suspect it will be plug and play. (be aware that OBD1 P72 automatic ECUs use an OBD2 style EPROM and you aren't likely to find anyone capable of reprograming the ECU for an LS-vtec setup, which kind of limits you to a stock GS-R swap. Regardless its not really worth doing, honda automatics don't last long when you start making more power than they were designed for, and they aren't cheap or easy to build up either. Theres a reason why you've never heard of anyone doing this.
Pic of JDM OBD1 Automatic P72 ECU shown below so you wont think i'm crazy about the EPROM issue, pic courtesy of Katman.
Old May 5, 2009 | 10:13 PM
im not gonna beat on the car, just to be different. i am planning to use my 95 LS tranny will that still work?
Old May 6, 2009 | 02:28 AM
94EG8's Avatar
Seagull Management
If you use the LS tranny and TCU you might be alright, i'm not sure how using a GS-R ECU with LS TCU is going to work as far as shift points are concerned, I think it will work though.
As far as doing this to be different, being different for the sake of being different is kind of stupid, do something different because its better, not just for the sake of being different.
Old Apr 7, 2016 | 08:33 PM
X2BOARD's Avatar
I hate to bring back such an old post on such a despised topic but... I must, as this thread was helpful in my search.
Trying to fix a botched B series auto swap into an EK3 CVT chassis. The car is obd1 and I have access to buy a GSR auto ecu. it's a stock motor so no need to attempt any ecu modification. What should I be looking for as far as a TCU in this car ? Is it external from the ecu ?
Old Jun 17, 2016 | 11:59 AM
92civlude's Avatar
The gsr automatic ecu does not support a separate tcu. The shift, tc controls, and speed sensors are wired directly into the ecu's 4th plug. My daughter has a DelSol with a gsr automatic swap and it's pretty sick! Shorter gearing than the ls transmission and it shifts at 7900 rpm!
delsolo95
Apr 5, 2010 10:02 AM
Rcp
Nov 1, 2007 08:20 AM
gstintegra92
Apr 2, 2004 10:35 AM
CallmeLuke
May 31, 2003 01:50 AM
