Possible to hit 13's with better transmission?
Old May 5, 2009 | 02:15 PM
Hanmin's Avatar
Default Possible to hit 13's with better transmission?
b18c1
LS transmission
xtd 12lb flywheel
vx wheels
walbro fuel pump that doesn't pick up fuel past half tank and I was just about half
EG Chassis.
With the LS transmission, shifting at 8.2k, each shift brings me down to 6k, which is just about where secondary butterfly's gives me the best power. I'm at 7k in fourth when I hit the finish line.
Old May 5, 2009 | 02:40 PM
95dxsir2's Avatar
Default Re: Possible to hit 13's with better transmission?
of course a closer gear ratio tranny will help on the time, but you have a ways to go to reach 13's. get rid of the gsr mani and get a skunk2 or somethin similar.
vx is 14", get some 15" drag radials.
Old May 5, 2009 | 02:44 PM
jnv255's Avatar
work on ur 60
Old May 5, 2009 | 04:59 PM
Hanmin's Avatar
What's a good 0-60? I did 2.3 pretty consistently. I tried launching a little higher, but then I had wheel hop, I'll post videos of my first two trial runs.
VX is 13's, HX is 14's. I won't lose acceleration with bigger tires?
First Trial run.
http://www.youtube.com/v/Tjj2Gz2x7a8
Second Trial Run
http://www.youtube.com/v/mdShd7Ee4iU
Old May 5, 2009 | 05:04 PM
Robs_B18c's Avatar
2.0 on street tires are good and 1.8 on drag radials
Old May 5, 2009 | 05:05 PM
stevenDAtegra's Avatar
Wasn't this in washington lol? I was going to go but my build isn't done and it's my senior year
Your times vary between 2 seconds so maybe work on timing and launching and throw a b16 tranny on. Then you may be close with good shifting
Old May 5, 2009 | 05:06 PM
SOHCinWA's Avatar
Not 0-60.. He is talking about your 60 foot times... I would opt for a 96-up GSR trans and possibly an LSD if you can swing it.. That will get your times down. Also, if you get a set of slicks you can knock it down by .500.. Pre loading... There are many different factors that come into play... If you can get your 60fts to 2.0 you could be looking at 14.0.. 1.8's should get you into the 13's... Keep going to the track and practice.. practice , practice , practice....
Old May 5, 2009 | 07:05 PM
Blown90hatcH's Avatar
Get a B16 or ITR tranny and I bet you will get in the 13s if not really close. Your 60' time needs work. Keep the VX wheels, they are super light at 8 lbs a piece. Even with crappy street tires, good throttle/clutch control will put you around a 2.0 60' time consistantly and you will see your times. What does the car weigh with you in it?
Old May 5, 2009 | 07:20 PM
integrawow's Avatar
Slicks.
Old May 5, 2009 | 07:24 PM
Originally Posted by integrawow
Slicks.
Coming from the guy wanting to make a street car street tire class....lol
Old May 5, 2009 | 08:55 PM
integrawow's Avatar
Pfffff, you didn't think i'd recommend him a tire that limits performance did you? lol
Old May 5, 2009 | 09:19 PM
Hanmin's Avatar
Umm, that 15 second run was when I had excessive wheel hop.
The car weighs 2250 ish with me in it. I'm only 135. That's without the back seats. Alright, when I get another chance to go to the tracks with a different transmission I'll post it up, thanks.
Old May 5, 2009 | 10:03 PM
ExospeedAMcrx's Avatar
Different gearing may get you close, but not into the 13s in my opinion. Diff trans will gain about .4 but if you work on the 60fts that will get you into the 13s for sure. Get slicks, drop the 60ft to a 1.8 and you'll gain another .8-.9 off the ET. Y
Old May 5, 2009 | 10:15 PM
SOHCinWA's Avatar
Basically what I said Wil... lol
Old May 5, 2009 | 10:18 PM
Lol. :p
A2_8U
Jul 25, 2006 10:31 PM
H22HondaCRX
Mar 2, 2005 04:02 PM
Sinner
Aug 18, 2003 11:43 PM
civteg1
Oct 10, 2002 07:10 PM
gsrvx
Sep 6, 2002 04:32 PM
