Suspension & Brakes Theory, alignment, spring rates....
Bolts broke on skunk2 camber kit
Old May 5, 2009 | 08:45 AM
Charlie Moua's Avatar
Default Bolts broke on skunk2 camber kit
Okay by kid brother trid to adjust his skunk2 camber kit last winter and broke 2 of the 4 bolts.
Do you know if I would be able to find these bolts at the harward store or have to get new camber kit?
Old May 5, 2009 | 08:57 AM
kaiba's Avatar
Default Re: Bolts broke on skunk2 camber kit
Reverse drill bit and use a 10mm bolt.
Btw, is that actual arm? If so, that's not skunk2.
Old May 5, 2009 | 09:30 AM
No it just wanted to use this pic cause it had the bolts circled... lol
Thanks, I'll try that.
Old May 5, 2009 | 06:14 PM
stumpyf4's Avatar
The screws are M6 and about 15mm long. You won't have to use that drill since the bottom of the screws should be visible since it's a through hole, get your needle nose vice grips and the broken screw should unthread.
AxKaose
Suspension & Brakes
Sep 28, 2009 08:46 AM
iLOVEthatEMone
14
Jun 28, 2007 01:52 PM
Hacemuy
Apr 4, 2003 11:36 PM
toeandheel
Mar 2, 2003 08:30 PM
95GSRRacer
Aug 22, 2002 08:35 AM
