building a 1.7 gsr and got a couple questions?
Old May 5, 2009 | 08:04 AM
febru_16's Avatar
Default building a 1.7 gsr and got a couple questions?
hi im building a 1.7 gsr all motor and i just wanted to know which type of cams, valves and pistons are are more durable and give out more perfomance my goal is like 260 hp my setup is the following in a crx si
arp connecting rod bolts
arp head bolts
shaved head
pro series valve springs
titanium retainers
intake
exhaust
bronze clutch
255 fuel pump
Old May 5, 2009 | 08:11 AM
88Hatchy's Avatar
Default Re: building a 1.7 gsr and got a couple questions?
260 is very ambitious for a 1.7L. I would set the hp goal at 200. Use stock valves, CTR pistons (you can't shave the head if you use these), Skunk2 Pro1 cams should work well, and get a Toda header.
Old May 5, 2009 | 08:48 AM
Ass$nyper's Avatar
Pirate General...YARRRR
260 is probably not happening off pump gas.
What's the motor for?
#s don't matter as much as powerband.
Ef3..saloon
Aug 18, 2015 01:42 PM
coupatroopa
95
May 20, 2011 10:26 AM
Na-Spirit
29
Sep 8, 2010 11:40 AM
Navy_CRX
Jun 18, 2010 07:38 PM
bllabong89
Nov 27, 2006 11:41 AM
