Sleeved Blocks D16 78mm H22 87mm B18 84mm - Custom Pistons D16, H22, B18
Need to get these things outta here to make room.
NEW! K24A4 Sleeved Block. $850.00
87mm bore
Includes main girdle, but missing bolts.
Optional Wiseco Piston set $300.00
Brand New! Pistons and wrist pins only. No ring set and locks.
K24A4 block is bored and honed to specs of this Wiseco Piston set.
GSR B18C1 Sleeved Block $750.00
84.5mm now, but recommended to use as 85mm.
Includes Main girdle and bolts.
NEW! CP Piston Set 84mm $410.00
SC7017 Dish 9.7:1
MB Fiberglass Dash: Universal $140.00
New!
Will fit in most common Honda used race cars.
May require trimming on certain areas to fit around cages, etc.
87mm bore
SC7017 Dish 9.7:1
New!
Also added: but no pics yet avail.
B18B Darton MID sleeved 81mm $1150.00
NEW! Freshly Sleeved and installed.
With main caps
Just need final hone for your pistons and youre good to go.
B18A Darton MID Sleeved 85mm+ $950.00
Was used for our backup motor. Planned to reuse it but never had the chance to rebuild motor.
Was last used as 84.5mm. Recommended for use as 85mm+
Just needs a new bore and hone and youre good to go.
With Main Caps.
With main caps
With Main Caps.
Added!
Pics up soon.
K24 Open Deck Sleeved 87mm $1490.00
New!
Bore and Hone matched to Wiseco Set
Includes main girdle but missing main bolts.
Wiseco 87mm 8.8:1 for use with K20 head
Brand New Set
Wrist pins incl.
No Rings
*Pics up soon(Both sold as package)
Pics up soon.
New!
Brand New Set
Wrist pins incl.
No Rings
added:
B20B1 Block with Main caps $225
Fresh and so clean!
for 84.5mm
New Bore and Honed block
Bare, no crank or oil pan or internals.
Fresh and so clean!
for 84.5mm
BRAND NEW! Turbosmart Pro-Gate 48mm $445.00
Just taken out of the box to test fit on a car.
the 78mm are 13:1 with an A6 head.
Yes we can do any compression in any bore you want. Custom PIstons are $640.00 for the complete set.
ExospeedAMcrx
Nov 30, 2013 07:22 AM
ExospeedAMcrx
Oct 28, 2009 02:53 PM
