B18 Sleeved Block, D16 78mm Sleeved Block, Custom H22, D16, B18 Pistons, B20 Block,
Got stuff laying around here for awhile. No need for them. Rather have someone else use them.
B18A1 Open Deck Sleeved 84.5mm+ $650.00
Last used as 84.5mm, Recommended 85mm+
Just fresh bore/hone needed and youre good to go!
Includes Main Caps.
H22 Darton MID Sleeved 87mm $1150.00
NEW! Fresh and so Clean!
87mm, ready to go! Just need final hone for your pistons.
DARTON MID!
No Core Exchange needed.
Includes Main Girdle.
D16A6 Open Deck Sleeved 78mm $600.00
Arias Custom D16A6 78mm 13:1 $450.00
(With Eagle Rods)
Recommend getting new rods or at least 2 rods.
1 missing rod cap and 1 missing rod bolt
Custom H22 Turbo Pistons : a deal at $580.00!
87.5mm, 10:1
Upgraded Wrist Pins
Complete Piston Ring Set
Top and skirt coating
New for all this at $850.00
Custom B-series Pistons 84mm, Hard Anodized with Buttons $650.00
84mm, 10.5:1
Upgraded Wrist Pins
Complete Ring set
Custom Hard Anodized! Exceeds wear characteristics of Ceramic coatings
Aluminum Pin buttons! No pin clips! NO worries of clips backing out.
This set is over $900 for a custom order.
Also have available:
No pics yet, sorry
B18B Darton MID sleeved 81mm $1150.00
NEW! Freshly Sleeved and installed.
With main caps
Just need final hone for your pistons and youre good to go.
B18A Darton MID Sleeved 85mm+ $950.00
Was used for our backup motor. Planned to reuse it but never had the chance to rebuild motor.
Was last used as 84.5mm. Recommended for use as 85mm+
Just needs a new bore and hone and youre good to go.
With Main Caps.
K24 Open Deck Sleeved 87mm $1490.00
New!
Bore and Hone matched to Wiseco Set
Includes main girdle but missing main bolts.
Wiseco 87mm 8.8:1 for use with K20 head
Brand New Set
Wrist pins incl.
No Rings
*(Both sold as package)
- Slight dent on corner of block and main girdle.
B20B1 Block with Main caps $225
Fresh and so clean!
for 84.5mm
New Bore and Honed block
Bare, no crank or oil pan or internals.
MB Fiberglass Dash: Universal $140.00
Will fit in most common Honda used race cars.
May require trimming on certain areas to fit around cages, etc.
Includes Main Caps.
DARTON MID!
(With Eagle Rods)
87.5mm, 10:1
Upgraded Wrist Pins
84mm, 10.5:1
Upgraded Wrist Pins
Complete Ring set
No pics yet, sorry
With main caps
With Main Caps.
New!
Brand New Set
Wrist pins incl.
No Rings
Fresh and so clean!
for 84.5mm
Also added: but no pics yet avail.
With main caps
With Main Caps.
With main caps
With Main Caps.
Added:
New!
Brand New Set
Wrist pins incl.
No Rings
*Pics up soon(Both sold as package)
New!
Brand New Set
Wrist pins incl.
No Rings
We have alot. We go through alot also. Remember we do race engines and block sleeving, so its just stuff we have done or worked on in the past. Theyre seriously just taking up space and its not fun to carry blocks from one shelf to the other. LOL. Just trying to make room for MORE blocks and see if anyone needs this stuff just here piling up.
added Fiberglass dash, couple more freshly honed B20 blocks for 84.5mm pistons.
old thread but if you still have sleeved d16 block let me know asap. interested in buying text if possible 209 509 8910
Hey Bud,
Whats your email address? This is what I am getting back.
Your mail message to the following address(es) could not be delivered. This
is a permanent error. Please verify the addresses and try again.
<sales@exospeed.com>:
child status 100...Error: autoreply='failed' reply_text='undefined' (LDAP-ERR #2.1.1)
The e-mail message could not be delivered because the user's mailfolder is full.
whats the lowest price on that h22 block.. and was it step decked? let me know.. very interested.. pm me
spoonhbk11
Engine Machining & Assembly
15
Feb 17, 2019 09:16 PM
ExospeedAMcrx
Oct 28, 2009 03:08 PM
ExospeedAMcrx
Oct 28, 2009 02:53 PM
